Viewport display error when In Front option is enabled
Closed, DuplicatePublic
Operating system: MacOS 10.13.6
Graphics card: Intel Iris Pro 1536 MB
Broken: 2.80, 1b6a394d862, blender2.8, 2018-12-03 23:39
Objects continue to reproject themselves whenever the "In Front" option is enabled under Viewport Display in the Object Properties tab.
Load the default startup screen, go to the Object Properties tab > Viewport Display > In Front (select). Rotate the 3D view and the cube will be reprojected multiple times across the screen view rather than spin. To clear this, go to the Collections panel, disable the collection in the viewport, reenable the collection, and the single cube is displayed again rather than multiple instances. However, if the viewport display is changed, the error reoccurs.
Related Objects
