Blender 2.8 - Eevee - Material Index is missing from the materials menu
Operating system: Linux 17.10
Graphics card: GTX 1080
Broken:234c1129715a022b5ff95ed3dcd8e275e3661f8c
EEVEE - Material Index is missing from the materials menu
  1. Open default blender
  2. Set renderer to cycles
  3. click on default cube
  4. go into material tab
  5. under settings, notice how pass index for the material is there
  6. switch renderer to eevee
  7. switch back to the materials tab
  8. notice how pass index is not there
Setting the pass index from cycles will influence eevee, there is just no way of changing it (outside of python) inside of eevee mode.
Dalai Felinto (dfelinto) triaged this task as Needs Information from User priority.Dec 7 2018, 1:37 AM
Could you share a file in eevee where material index is used?
The compositing pass Material Index is not supported for EEVEE.
Actually the Material Index is supported... It just isnt exposed to the UI.
PLease find attached a simple file which shows that cycles and EEVEE both using the material index.
Carlo Andreacchio (candreacchio) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Dec 7 2018, 1:47 AM
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.Dec 7 2018, 11:19 AM
The changes in cycles seems to indeed affect the eevee render.
Ah alright. I thought you were talking about the compositing nodes, not material nodes. Fixed now.
