Unable to Create Lofted shapes from NURBS Circle
Operating system:Windows 7
Graphics card:
Blender 2.80
Broken: in version 2.80 - NURBS circle is not visible,is not possible to create lofted shape in Blender 2.80
(example: 2.79b release)
Worked: 2.79b
**unable to create lofted shapes - NURBS Circle is not visible,it does not have make segment option{F5868279}
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.
This is a mixed bag of issues:
  • Nurbs circle and curve dont draw in objectmode [but that has already reported in T58298]
  • entries are missing from the Surface menu
here is 2.79
here is 2.8
@William Reynish (billreynish) : should we add menu entries back?
That being said, functionality is still there and intact, meaning you can select those Nurbs curves, join them, enter editmode and execute Make Segment from the operator search...
Confirming for now [regarding those menu entries -- will happily add them back, but waiting for @William Reynish (billreynish) for approval...]
The issue here is that we have added a new menu called Control Points where these things in Curve Edit Mode. We could add that to Surfaces too.
Ah, I see. If you have no objections, I will add Control Points (Segments, too, right?)
Yes that makes sense I think.
