Sculpted changes dissapear visually when selecting a second object #58966
6 Participants
Reference: blender/blender#58966
win10 64, nvidia 1060
Broken: blender-2.80.0-git.606223f6a61-windows64
When you disable "Lock object mode" in the Edit menu, and sculpt on one ojbect, if you select a second object, the sculpted changes will "disappear" from the first. The changes are still there, you just have to select the first object and you can see them, but selecting back and forth between the two objects will make the changes appear and disappear. And in order for this to not happen, you have to get out of Sculpt mode, but it will happen once you sculpt again.
Using the attached blendfile, make sure "Lock object mode" is disabled in the Edit menu. The red monkey is already selected and in sculpt mode. Sculpt visible changes on the red monkey, select the white monkey (right click select presumably) and see the changes dissapear, select the red monkey again and see the changes come back.
Animated gif:
bug3.blend
Added subscriber: @moisessalvador
#63863 was marked as duplicate of this issue
#63216 was marked as duplicate of this issue
#62182 was marked as duplicate of this issue
#60989 was marked as duplicate of this issue
#58821 was marked as duplicate of this issue
Added subscriber: @ZedDB
I'm guessing that the changes are not propagated to the object mode mesh unless you exit sculpt mode.
Added subscribers: @ideasman42, @Sergey
@ideasman42 , Not sure if changing active object in such configuration is expected to load sculpt changes back to actual object, or whether drawing is making a wrong decision about drawing sculpt object not using PBVH.
Added subscriber: @EdHernandez
Added subscriber: @Jub2982
@Sergey it's not, this was a design choice to allow people to quickly switch between sculpting different objects.
Most likely the issue is our drawing code which only uses sculpt mode drawing for the active sculpt object.
Added subscriber: @GustavoRosa
Added subscribers: @gabbitt, @WilliamReynish
Added subscriber: @CraigJones
This issue was referenced by
d4827cfa81
