Edit mesh path select doesn't update gizmo location #58982
2 Participants
Reference: blender/blender#58982
Operating system: Arch Linux
Graphics card: GTX 1060 6GB
Any version 2.8
Sorry, I do not know how this cursor is called correctly.
I will call gizmo.
When selected, gizmo shows the center of the selection.
When sequential allocation shift.
Or when you select the loop.
If you select by pressing Ctrl, gizmo remains with the first selected item.
If you switch to object mode.
If you change the selection element (vertices, edges, faces).
If you change the mode (Transform, Move, Rotate, Scale)
Gizmo appears in the right place.
Start the default scene with the cube.
Switch to edit mode.
Select all and subdivide several times.
Deselect.
press Ctrl
Select item, select another
See where is gizmo.
Make sure that gizmo is near the first selected item.
Added subscriber: @Povert
Edit mode. Overlays. Active Tools.to Edit mesh path select doesn't update gizmo locationChanged status from 'Open' to: 'Resolved'
Fixed
f13a4b2f12
