Keyframing problem with SHIFT+D
Operating system: Win 10
Broken: 2.8 beta
Worked: 2.79
duplicating and replacing key frames using SHIFT+D makes some weird results. Please see the video
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.
When you do this you are ending up with 2 keyframes on the same frame.
This only seems to happen when you move/duplicate keyframes in the timeline-dopesheet (whereas when you do this in the Graph Editor ot the 'real' Dopesheet, these seem to be merged automatically...)
This is happening/should happen in posttrans_fcurve_clean(), will check why this is not happening here...
Not 100% sure if we run into trouble with D4061, but at least this is now also merging the keyframes (as in the 'real' Dopesheet)
