Black 3D / Corrupted viewport with Intel HD and Windows 8.1 / Windows 7 #59014
Closed
opened 2018-12-08 12:17:24 +01:00 by Bhanu · 53 comments
Operating system:Windows 8.1
Graphics card:Integrated Intel HD Graphics
Broken:
(example: 2.80, edbf15d3c0, blender2.8, 2018-11-28, as found on the splash screen)
The 3D Viewport looks complete black, meshes become visible after changing shading type, but grid floor is never visible
Start the program and the error is right there.
**System Information** Operating system:Windows 8.1 Graphics card:Integrated Intel HD Graphics **Blender Version** Broken: (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) **Short description of error** The 3D Viewport looks complete black, meshes become visible after changing shading type, but grid floor is never visible ![image.png](https://archive.blender.org/developer/F5884406/image.png) **Exact steps for others to reproduce the error** Start the program and the error is right there. Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @noob_user
#63104 was marked as duplicate of this issue
#58954 was marked as duplicate of this issue
#62888 was marked as duplicate of this issue
#62796 was marked as duplicate of this issue
#60064 was marked as duplicate of this issue
#62728 was marked as duplicate of this issue
#61999 was marked as duplicate of this issue
#62556 was marked as duplicate of this issue
#58589 was marked as duplicate of this issue
#62367 was marked as duplicate of this issue
#60189 was marked as duplicate of this issue
#60152 was marked as duplicate of this issue
Added subscriber: @ZedDB
Try a newer blender beta https://builder.blender.org/download/
And also try to update your GPU drivers.
Report back your results.
Try a newer blender beta https://builder.blender.org/download/ And also try to update your GPU drivers. Report back your results.
Author
The issue is still as it is.
Used the latest build: Date:2018-12-16 23:25 Hash: 9149e89421 and GPU drivers are up-to-date
> In #59014#578077, @ZedDB wrote: > Try a newer blender beta https://builder.blender.org/download/ > And also try to update your GPU drivers. > > Report back your results. ![image.png](https://archive.blender.org/developer/F5978625/image.png) The issue is still as it is. Used the latest build: Date:2018-12-16 23:25 Hash: 9149e894210 and GPU drivers are up-to-date
Clément Foucault was assigned by Sebastian Parborg 2018-12-17 10:34:13 +01:00
Attach the output when you run blender with "--debug-gpu". You can also try and see if "--debug-gpu-force-workarounds" solves the issue.
Author
with --debug-gpu output is:
tried "--debug-gpu-force-workarounds" , but the problem still persists
> In #59014#581831, @ZedDB wrote: > Attach the output when you run blender with "--debug-gpu". You can also try and see if "--debug-gpu-force-workarounds" solves the issue. with --debug-gpu output is: ![image.png](https://archive.blender.org/developer/F6017956/image.png) tried "--debug-gpu-force-workarounds" , but the problem still persists
Added subscribers: @Ron-P, @brecht
Brecht Van Lommel changed title from 3D ViewPort complete black, nothing visible to Black 3D viewport with Intel HD graphics 2019-01-05 23:30:01 +01:00
Added subscriber: @RalphBiggins
Added subscriber: @mbutscher
Added subscriber: @MiG_1968
Brecht Van Lommel changed title from Black 3D viewport with Intel HD graphics to Black 3D viewport with Intel HD and Windows 8.1 2019-03-11 18:29:36 +01:00
This seems specifically related to Windows version 8.1, or at least versions before 10.
Added subscribers: @bzarnal, @fclem, @Sirithang, @mariohenriquelopes3, @tier777, @gazofnaz, @melisa, @JacquesLucke
Added subscriber: @niko_f5
I updated to Win10 and none of the problems are visible any more. No other changes were made to the computer.
This comment was removed by @niko_f5
*This comment was removed by @niko_f5*
Niraj closed this issue 2019-03-16 14:37:11 +01:00
The problem got solved.
As suggested in one of the solutions, I changed my system default graphic driver to Nvidia from Intel.
Now it's working just fine.
Thanks a lot folks for your quick help.
The problem got solved. As suggested in one of the solutions, I changed my system default graphic driver to Nvidia from Intel. Now it's working just fine. Thanks a lot folks for your quick help.
Changed status from 'Resolved' to: 'Open'
Removed subscribers: @niko_f5, @RalphBiggins
Leaving open the report for others.
Added subscribers: @XeroDarkhoter, @LazyDodo
Added subscriber: @callmecraig
Found this thread after having the same issue.
Intel 4th Gen i5
Integrated HD Graphics
Windows 8.1
I have done the following:
Installed the latest version of Blender 2.8 as of today.
Updated graphics driver to the latest version as of today.
and ran debug_gpu with the following results:
blender_debug_output.txt
Running in debug_gpu_glitchworkaround yielded no results.
Found this thread after having the same issue. Intel 4th Gen i5 Integrated HD Graphics Windows 8.1 I have done the following: Installed the latest version of Blender 2.8 as of today. Updated graphics driver to the latest version as of today. ![Screenshot (41).png](https://archive.blender.org/developer/F6835913/Screenshot__41_.png) and ran debug_gpu with the following results: [blender_debug_output.txt](https://archive.blender.org/developer/F6835926/blender_debug_output.txt) Running in debug_gpu_glitchworkaround yielded no results.
Added subscriber: @Arris
Added subscriber: @VijaySridhara
Windows 7, Release 2019-03-18, On Win 7, and Intel Graphics Card, issue still remains.
Windows 7, Release 2019-03-18, On Win 7, and Intel Graphics Card, issue still remains. ![img_20190319171653.png](https://archive.blender.org/developer/F6849312/img_20190319171653.png)
Changing default graphic card solved the problem in my case. Thank you for delivered solution.
Added subscriber: @USER200
We haven't been able to reproduce this ourselves as developers, but marking as high priority due to the number of reports.
We've ordered a CPU with Intel HD graphics and will set up a system with Windows 7/8 to try to reproduce this.
Meanwhile the solution is to upgrade to Windows 10.
We haven't been able to reproduce this ourselves as developers, but marking as high priority due to the number of reports. We've ordered a CPU with Intel HD graphics and will set up a system with Windows 7/8 to try to reproduce this. Meanwhile the solution is to upgrade to Windows 10.
Added subscriber: @caleido
Added subscriber: @Stan_2016
I have had the same problem for the last two days, and as many people have already said it works fine on 2.79
Added subscriber: @DoWagner
Clément Foucault changed title from Black 3D viewport with Intel HD and Windows 8.1 to Black 3D / Corrupted viewport with Intel HD and Windows 8.1 / Windows 7 2019-03-25 20:10:17 +01:00
Update OS to Windows 10.
Blender 2.8 works fine now.
Update OS to Windows 10. Blender 2.8 works fine now.
Removed subscriber: @MiG_1968
Added subscriber: @gt324
This issue was referenced by cc73d59ad5
This issue was referenced by cc73d59ad580f9f20286298b0d4547f0b1d87eda
Just downloaded and tested blender-2.80-cc73d59ad580-win64 on the same machine used to report the bug in ticket #58589.
Everything works, looks great. Good job!
Thanks guys.
Just downloaded and tested blender-2.80-cc73d59ad580-win64 on the same machine used to report the bug in ticket #58589. Everything works, looks great. Good job! Thanks guys.
14 Participants
Reference: blender/blender#59014
