Blender eevee render Black Glich (Node Editor)
Operating system: Macbook Air
Graphics card: Intel HD Graphics 6000 1536 MB
Broken: eevee rendering (Blender V2.8)
Worked: I fixed it by Restarting the Program.
After Adding a whole bunch of nodes changing principles using eevee (Development) the program lagged and started to turn black and spread on the screen. i couldent take a picture of the problem at the time but i did get the node edit i was using that made it occur.
To Redo (At least what i did) Go to where the last node is connected to the output and disconnect it. After connect it again and mess around with the noise texture plus the color ramp (While connected to the output). It gave that weird glitch to me but it might be a low core problem or something. Im not that worried but i hope you can fix it incase someone else runs into this.
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.Jan 23 2019, 1:57 PM
The attached file does not seem to come with any node trees. All materials have the default node shader setup.
Is this still and issue for you with the latest blender beta?
Brecht Van Lommel (brecht) closed this task as Archived.Mar 1 2019, 5:02 AM
Following bug tracker policy, closing report after 7 days due to insufficient information to investigate further. We can reopen the report if more information is provided.
