Blender 2.8 (9a8b6d51c1
) - Crash when going in Edit Mode with Multiresolution modifier #59168
6 Participants
Reference: blender/blender#59168
Operating system: Windows 10 Pro 64 bit
Graphics card: AMD Ryzen 5 2400G with Radeon Vega 11 Graphics
Broken: Blender 2.80 (December 11, 2018 - hash - win64)
I have an object with a Multiresolution modifier and sculpting on it.
When I try to go to the Edit mode Blender instantly crashes.
This happens every time, no matter what project I'm working on.
The error message from the command prompt stays the same every crash.
Error Output from command prompt:
C:\Program Files\Blender Foundation\Blender 2.8>blender.exe -w -d
Switching to fully guarded memory allocator.
Blender 2.80 (sub 36)
Build: 10/12/2018 17:56 Windows Release
argv- [x] = blender.exe
argv- [x] = -w
argv- [x] = -d
read file C:\Users\Administrator\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
Read prefs: C:\Users\Administrator\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
read file
found bundled python: C:\Program Files\Blender Foundation\Blender 2.8\2.80\python
Read blend: C:\Users\Administrator\untitled.blend
read file C:\Users\Administrator\untitled.blend
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FF60BBF73FF
Module : C:\Program Files\Blender Foundation\Blender 2.8\blender.exe
system-info.txt
Added subscriber: @HADESBLACK
Added subscriber: @birdsnotberries
Environment:
Arch Linux latest
i5-4278U, Iris integrated
Blender built using AUR git package , build hash (from
--version
)9a8b6d51c12
I'm getting something similar with the mirror modifier - adding the modifier and then going to edit mode crashes Blender, as does being in edit mode and then adding the modifier.
When this happens, the console prints
and
/tmp/barrel.crash.txt
containsBlender 2.8 (9a8b6d51c12) - Crash when going in Edit Mode with Multiresolution modiferto Blender 2.8 (9a8b6d51c12) - Crash when going in Edit Mode with Multiresolution modifierThat's interesting. I've only experienced this problem since I swapped out the Subdivision modifier with the Multiresolution modifier to allow much better sculpting.
Must be a problem with all modifiers that store specific information about the original and the modified mesh then.
I did a super-quick test (add the modifier to the default cube; hit tab; see if it crashes) with all the modifiers (there might be a few that slipped through if they needed a setting changed before they started doing anything or something)
The modifiers that caused Blender to crash for me were:
Here's the error log from that testing.
Funny how you list the Subdivision Surface at the modifiers that caused your Blender to crash, but apparently having the Multiresolution got working since it's not on your list...
while at me, it's the exact opposite:
Edit mode with Subdivision Surface = No problem
Edit mode with Multiresolution = Dead
But at least I can confirm that the other modifiers that you've listed are also causing crashes.
Added subscriber: @capnm
Mesh with Subdivision Surface or Mirror modifier -> edit mode
( Linux
d415b5c7b8
)@fclem AFAIK the commit
ae1f563899
broke it.
Added subscriber: @fclem
@capnm I can't get it to crash here. Are you sure you can repro with latest 2.8 (from git)?
@fclem Yes, e.g. just open the file F5916342 The bisect log:
It opens fine here. All the commit you bisected are from yesterday.
That's in the Europe today ;-)
The last commit without crashes was
Blender still crashes here right now when you open that file ¯_(ツ)_/¯
Possible duplicate issues #59187 #59184 #59183
$ build8/bin/blender /tmp/test/ModellingEar.blend
$ gdb build8/bin/blender
Added subscriber: @boarnoah
I just recompiled Blender and it seems to be working fine - build hash
b87b6e8e289
Can confirm that
b87b6e8e28
has fixed it ?Possible duplicate issues += #59224 #59222 #59229
Added subscriber: @ideasman42
@ideasman42
I just got another related? crash:
ae1f563899
eedd679ef2
Reproducible here e.g. with the file from #59183:
Crash_editmode.blend
file@fclem so far I haven't got any edit-mode crash after
10eb92035c
.Thanks.
