Compress file isn't working when Load UI is disabled
Operating system: Linux
Graphics card: GeForce GTX 780/PCIe/SSE2'
Broken: blender2.8, commit date: 2018-12-10 23:13, hash: a49fdbcc674
In the user preferences when load UI is disabled and Compress File turned on, compress file isn't activated by default when saving files.
Based on the default startup :
  1. in the user preferences / Files , activate Compress File, and desactivate Load Ui.
  2. Save preferences
  3. Save the default scene, compress option should be enabled by default, this will give a 100ko file
  4. close blender
  5. open blender, load the previously saved file
  6. save or save-as the file, compress option should be turned off, and saving should give a 610 Ko file
This option should have a similar behavior of relative path or load ui option,
What is set in the preferences should be the default when files are saved .
