Loop Cut, no slide
Closed, ResolvedPublicBUG
Broken: 2.80
Worked: all prior releases
As per title, after cut, older version allowed the cuts to be slid into position
You still can. I can't reproduce this issue.
Sorry, I see now that it lets you slide whilst you hold the mouse button down. ( That is different to 'old' blender, I'm sure it slid after the click to cut and then click to confirm position)
Yevgeny Makarov (jenkm) changed the task status from Duplicate to Unknown Status.Aug 1 2019, 11:22 AM
When you call the "Loop Cut and Slide" via hotkey (Ctrl-R):
you click to cut, then you can slide, and click again to confirm.
But if you call the same operator via context menu (in edge select mode), it works differently:
you need press and hold to slide, and release to confirm.
Similar to the behavior of the Loop Cut active tool.
I don't think this inconsistency is intentional.
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to Low.Aug 21 2019, 3:34 PM
I can confirm this issue. The behavior should be more consistent.
