Edge Crease have less effect in 2.8 than in 2.79 #59447
Reference: blender/blender#59447
Operating system: windows
Broken: 2.80,
f13a4b2f12
In subdivision modifier and smooth shading, If I set edge crease to max 1, It does not reach the edge as it does in 2.79.
add a cube.
add subdivision modifier
and in edit mode set edge crease (in properties panel) to 1.
Added subscriber: @Yash_Patel
Added subscriber: @solartistic
Edge Crease has the same effect. Compare the result in subdivion level 3 instead of 1 and you will see it looks the same.
No bug is described here, just a diverent way the modifier works.
Added subscriber: @mont29
Indeed, and since the backend code for subdivision was totally replaced by new OpenSubDiv lib in 2.8, some changes are to be expected, too.
