hook bug
select "Empty" and try to translate it. Instead of deforming the curve at that point, the whole curve moves:
Jacques Lucke (JacquesLucke) triaged this task as Needs Information from User priority.
Are you sure that you did not accidentally hooked all points to this empty?
The fact that this empty is exactly in the center of all curve points (in edit mode) also supports this claim.
Can you reproduce the error in a new file?
at least, when i subdivide a curve twice and then try to create a hook at the first point, it gets shifted away from the point:
the image above already shows my simplified bug. Add a curve, subdivide it twice in edit mode, select the first contol point and hit ctrl-h.
Philipp Oeser (lichtwerk) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Jan 15 2019, 12:02 PM
Jacques Lucke (JacquesLucke) triaged this task as Needs Information from User priority.Jan 15 2019, 12:09 PM
Seems to work as expected. Can you reproduce the bug in a newer build?
Jacques Lucke (JacquesLucke) claimed this task.
