[object mode] circle/ lasso select only works on object origins
Closed, InvalidPublic
Operating system: Windows 10 64 bit
Graphics card: Nvidia gtx 860m
Broken:
2.79b release
version: 2.80 (sub 37), branch: blender2.8, commit date: 2018-12-16 00:27, hash: 4488056f3d9, type: Release
when in object mode and using circle or lasso select, objects will only be selected when the objects origin is within the circle. when using box select its enough if any part of the object is within the selection
  1. create a couple of duplicated cubes, stay in object mode
  2. use box select and try to select the cubes on any part of the mesh
  3. now switch to lasso or circle select tool
  4. try to select the objects on any part of the mesh again
  5. notice how its only possible with these selection methods if the origin of the object is within the selection
