Blender 2.8 2018-12-04 19:42 crash with smoke sim #59522
6 Participants
Reference: blender/blender#59522
Operating system: Windows 10
Graphics card: Titan X Pascal
Broken:
(2.8 Beta release)
(2.80,
be012c88c5
, blender2.8, 2018-12-04, as found on the splash screen)Worked: (optional)
Blender crashes when simulating smoke after checking "high resolution" with cycles enabled as viewport renderer. The crash occurs when moving the playhead to the begginning of the frame range in order to play back the simulation. smoketest.blend
Added subscriber: @CorruptFrame
Added subscriber: @lichtwerk
Cannot reproduce here.
Tried opening the file, enable "High Resolution", switched to viewport render, moved to frame 1, pressed play to start animation --> still no crash...
Please make sure that the viewport render is set to Cycles with CPU compute. I though originally that I was set to GPU compute but I was mistaken, and as it turns out when GPU is enabled it doesn't crash. It is only a problem with CPU compute. I am using a AMD Ryzen Threadripper 1950X. With 64gb of DDR4 333Mhz.
ADDITIONAL INFORMATION: I was wrong again. GPU works better and crashes less often but it still crashes after playing around a little bit with playback and settings.
Increasing resolution divisions seems to crash it. At 32 GPU seems to be able to handle it okay with fewer crashes. but switching to 64 crashes it every time.
Added subscriber: @StephenSwaney
Seems to be working under Linux with CPU.
Can you try a newer build?
If I change the settings and start playing back the simulation while in solid display view things seem to play back fine if I switch to cycles afterwards. It seems that the crashes only occur consistently while altering the resolution settings of the sim while in cycles preview.
I'll try a newer build.
It still happens in the latest Windows x64 build (12-18-2018) but it seems to be only when I change any of the settings while Cycles is enabled then try to scrub the timeline or jump to the first frame. It seems like I don't have as many issues if I change the settings in solid view then switch to cycles after playing through the sim once.
Added subscriber: @henryschreiner
I've seen this crash as well, and was about to report it when I found this issue. I am on macOS, and just rebuilt Blender 2.8. It's really hard to consistently reproduce at the same point, but it does happen somewhere in the steps I was doing:
It's almost always related to moving in the timeline. The crash is pretty quick, but if it locks up, it lasts for minutes before I gave up and killed it. Some steps may be optional; it's inconsistent in crashing as it is.
Added subscriber: @ZedDB
I can't reproduce this on my end. Is this still and issue with a build from today?
Added subscriber: @brecht
Following bug tracker policy, closing report after 7 days due to insufficient information to investigate further. We can reopen the report if more information is provided.
