Grease Pencil Edit Mode: Individual Origins does not work #59546
Closed
opened 2018-12-18 09:45:44 +01:00 by William Reynish · 10 comments
Operating system: macOS 10.14.2 (18C54)
Graphics card: AMD Radeon R9 M395X 4096 MB
Broken: Blender 2.80 beta Dec 18 2018
  • Add a GP Object and draw some shapes
  • Go to Edit Mode and set pivot to Individual Origins
Rotate or Scale with all shapes selected. You'll see that the entire collection of shapes are transformed as a whole, rather than as individual items.
This blend file has two identical objects - one is a mesh and the other is a GP object:
GP_individual_origins_bug.blend
Enter Edit Mode for each and scale the items. Observe how the mesh object scales from the individual mesh islands, but the GP object in Edit Mode does not.
**System Information** Operating system: macOS 10.14.2 (18C54) Graphics card: AMD Radeon R9 M395X 4096 MB **Blender Version** Broken: Blender 2.80 beta Dec 18 2018 **Short description of error** Grease Pencil Edit Mode: Individual Origins does not work **Exact steps for others to reproduce the error** - Add a GP Object and draw some shapes - Go to Edit Mode and set pivot to Individual Origins # Rotate or Scale with all shapes selected. You'll see that the entire collection of shapes are transformed as a whole, rather than as individual items. This blend file has two identical objects - one is a mesh and the other is a GP object: [GP_individual_origins_bug.blend](https://archive.blender.org/developer/F5990956/GP_individual_origins_bug.blend) Enter Edit Mode for each and scale the items. Observe how the mesh object scales from the individual mesh islands, but the GP object in Edit Mode does not.
Added subscriber: @WilliamReynish
Added subscribers: @brecht, @antoniov
@brecht you changed how the origin was calculated because I did not know this area of the code. Could you take a look on this?
Antonio Vazquez was assigned by Brecht Van Lommel 2018-12-18 17:54:27 +01:00
This is just not implemented for grease pencil. I think it mainly needs changes in transform_conversions.c. See for example how createTransEditVerts does it for edit mesh. It seems to work roughly like this:
  • Compute which vertices belong to the same "island", that is which vertices are connected to each other. Not sure what the equivalent is for grease pencil, maybe just points in the same stroke? I guess there is not any more connectivity information, unless you try to do something clever with detecting overlapping strokes.
  • Then for each vertex, it sets a td->center and td->axismtxto the center and axis of the island it belongs to, rather than using the same values for all.
This is just not implemented for grease pencil. I think it mainly needs changes in `transform_conversions.c`. See for example how `createTransEditVerts` does it for edit mesh. It seems to work roughly like this: * Compute which vertices belong to the same "island", that is which vertices are connected to each other. Not sure what the equivalent is for grease pencil, maybe just points in the same stroke? I guess there is not any more connectivity information, unless you try to do something clever with detecting overlapping strokes. * Then for each vertex, it sets a `td->center` and `td->axismtx`to the center and axis of the island it belongs to, rather than using the same values for all.
@brecht I see what you mean. I will try to implement that.
@brecht I created this code P875 but still does not work. I have checked and the center is right by stroke (local coords). What am I missing?
The matrix is filled with this code:
/* apply parent transformations */
copy_m3_m4(td->smtx, inverse_diff_mat); /* final position */
copy_m3_m4(td->mtx, diff_mat);  /* display position */
copy_m3_m4(td->axismtx, diff_mat); /* axis orientation */
@brecht I created this code [P875](https://archive.blender.org/developer/P875.txt) but still does not work. I have checked and the center is right by stroke (local coords). What am I missing? The matrix is filled with this code: ``` /* apply parent transformations */ copy_m3_m4(td->smtx, inverse_diff_mat); /* final position */ copy_m3_m4(td->mtx, diff_mat); /* display position */ copy_m3_m4(td->axismtx, diff_mat); /* axis orientation */ ```
Member
Added subscriber: @zazizizou
Member
@antoniov: I submitted a patch to fix this: D4156. Center computation was done correctly, the problem was that transdata_check_local_center() didn't support GP objects.
@antoniov: I submitted a patch to fix this: [D4156](https://archive.blender.org/developer/D4156). Center computation was done correctly, the problem was that `transdata_check_local_center()` didn't support GP objects.
This issue was referenced by 38796a4971
This issue was referenced by 38796a4971afdd58e58bcfe043fbdb21153dfcc2
5 Participants
Reference: blender/blender#59546
