Disable render keyframes not working
Closed, DuplicatePublic
Operating system: Windows 10 64bit6
Graphics card:GTX 1080ti
Broken:2.80, 8839152abf5
(example: 2.79b release)
Rendered frames do not take "disable render" keyframes into account.
Based on the default startup or an attached .blend file (as simple as possible). Put a disable render (off=visible) keyframe on frame 1 for the default cube and a disable render (on = invisible) on frame 10. Render on frame 5 and render on frame 15 they should be different but are the same. Depends on the last state of the disable render that was clicked, not on the keyframed data or apparent current state based on keyframes.
