Select Multiple Objects Not Working As Expected #59741
7 Participants
Reference: blender/blender#59741
Operating system: Windows 10
Graphics card: Intel HD Graphics 530
Broken: 2.80 Beta
(example: 2.79b release)
(example: 2.80,
edbf15d3c0
, blender2.8, 2018-11-28, as found on the splash screen)Worked: (optional)
Selecting multiple objects in select box mode not working as expected. It can only select object with
origin
mark and maximum of 2 objects on the default startup screen.Note: Blender version 2.79 is still installed.
A. Default startup
B. Custom blend file
bug_report.blend
bug_report.blend
origin
mark visible and ignore all other objects.origin
mark visible and they won't be selected, because it is only working on the object that hasorigin
mark visible.Added subscriber: @wantToKnow
Added subscriber: @StephenSwaney
I cannot reproduce this on Linux. All objects seem selectable.
I wonder if this is a picking issue.
Does turning on OpenGL Depth Picking help? ( Preferences -> System -> General )
Or changing the Selection method from Automatic to something else?
No, it is not. Even worse, it won't select anything when the Selection method is changed to OpenGL Select.
Added subscriber: @ZedDB
I can not reproduce this either on my end.
Could you try updating you GPU drivers and also try the latest blender beta version and see if that helps?
It is not working either.
Does it work if you download this dll and copy it so its located in the same directory as 'blender.exe' and run Blender normally?
It slow down blender and make it not responding.
And you are using the latest drivers from here: https://downloadcenter.intel.com/product/80939/Graphics-Drivers ?
Be sure to remove that .dll file not that you have tested with it btw.
Added subscriber: @mont29
Added subscriber: @zgorg
I just tried this dll too and blender freeze. update from today. pro enough?
I see no more subject opened for this problem and all mine closed of course. and always the same answers. be more specific. I can't reproduce...but it's working under 2.79. and under 2.8 all selection working exept the select box to add more object that the first one and the lamp. it's a strange bug isn't? and it's working when all origins enabled. so if it's a problem of Open GL depth picking why it's the hell it's working in other situations?
only possible conclusion a select box issue
Removed subscriber: @zgorg
Added subscriber: @ZeroNyx
I also have this exact same issue, I've posted a gif here ( https://blender.stackexchange.com/questions/137224/can-not-get-selection-box-selecting-more-than-one-object-in-blender-2-8 ) which may show the issue in action. I'm not sure how to further diagnose. Sorry to revive an old task but this seems to have fallen by the wayside.
Added subscriber: @FernandoDAndrea
It seems I got this bug on an Intel HD 4000. Maybe I can add some further information:
In Blender 2.80 freshly installed from Blender.org to said Intel HD 4000 desktop machine, both box and direct click selection work ok for meshes (triangles), but behave erratically on a group of empties (possibly because they lack geometry?).
Sometimes, none are selected (even if the box encompasses all protrusions of the empty), sometimes all of them (even those clear away from the box). The direction of the viewport seemingly affect the "selectability" of the empties. Click to select almost never works (but sometimes it does).
The file came from 2.79c, but both tools work as expected in my Nvidia GTX 1070 notebook ?, in the very same file.
I've tried to change Edit > Preferences > Viewport > Selection > OpenGL Depth Picking both on and off, to no avail.
