IPython.embed() throws RuntimeError
Open, Confirmed, LowPublic
Operating system: Win 10 X64
Graphics card: GTX 1070
Broken: blender-2.80.0-git.1fc75dbbceea-windows64
Based on https://docs.blender.org/api/blender2.8/info_tips_and_tricks.html?highlight=ipython, it is recommended that one can use Ipython in the internal terminal
Firing these commands throws bunch of errors in Blender.
Bear in mind that I have Ipython and notebook installed properly (system wide, which also Blender uses) and they seem to function as expected under regular Python/Cmd terminals, including the IPython.embed()
Make sure Ipython is installed
Fire the commands below in Blender Py terminal
import IPython  (This does not produce any error, import succesfull)
IPython.embed() (alot of errors)
>>> import IPython
>>> IPython.embed()
Python 3.7.0 (default, Aug 26 2018, 16:05:01) [MSC v.1900 64 bit (AMD64)]
Type 'copyright', 'credits' or 'license' for more information
IPython 7.1.1 -- An enhanced Interactive Python. Type '?' for help.
RuntimeError                              Traceback (most recent call last)
C:\BLENDER_28\2.80\python\lib\code.py in runcode(self, code)
     88         """
     89         try:
---> 90             exec(code, self.locals)
     91         except SystemExit:
     92             raise
<blender_console> in <module>
C:\BLENDER_28\2.80\python\lib\site-packages\IPython\terminal\embed.py in embed(**kwargs)
    387         frame.f_code.co_filename, frame.f_lineno), **kwargs)
    388     shell(header=header, stack_depth=2, compile_flags=compile_flags,
--> 389         _call_location_id='%s:%s' % (frame.f_code.co_filename, frame.f_lineno))
    390     InteractiveShellEmbed.clear_instance()
    391     #restore previous instance
C:\BLENDER_28\2.80\python\lib\site-packages\IPython\terminal\embed.py in __call__(self, header, local_ns, module, dummy, stack_depth, global_ns, compile_flags, **kw)
    227         # our call and get the original caller's namespaces.
    228         self.mainloop(local_ns, module, stack_depth=stack_depth,
--> 229                       global_ns=global_ns, compile_flags=compile_flags)
    230
    231         self.banner2 = self.old_banner2
C:\BLENDER_28\2.80\python\lib\site-packages\IPython\terminal\embed.py in mainloop(self, local_ns, module, stack_depth, display_banner, global_ns, compile_flags)
    322
    323         with self.builtin_trap, self.display_trap:
--> 324             self.interact()
    325
    326         # now, purge out the local namespace of IPython's hidden variables.
C:\BLENDER_28\2.80\python\lib\site-packages\IPython\terminal\interactiveshell.py in interact(self, display_banner)
    471
    472             try:
--> 473                 code = self.prompt_for_code()
    474             except EOFError:
    475                 if (not self.confirm_exit) \
C:\BLENDER_28\2.80\python\lib\site-packages\IPython\terminal\interactiveshell.py in prompt()
    248             def prompt():
    249                 prompt_text = "".join(x[1] for x in self.prompts.in_prompt_tokens())
--> 250                 lines = [input(prompt_text)]
    251                 prompt_continuation = "".join(x[1] for x in self.prompts.continuation_prompt_tokens())
    252                 while self.check_complete('\n'.join(lines))[0] == 'incomplete':
C:\BLENDER_28\2.80\python\lib\site-packages\IPython\utils\py3compat.py in input(prompt)
    152 # to forward requests to a frontend.
    153 def input(prompt=''):
--> 154     return builtin_mod.input(prompt)
    155
    156 builtin_mod_name = "builtins"
RuntimeError: input(): lost sys.stdin
OS: Win 10, Blender a4e4d9f0ab89, IPython from Anaconda distribution
From https://docs.blender.org/api/blender2.8/info_tips_and_tricks.html?highlight=ipython:
In the middle of a script you may want to inspect some variables, run some function and generally dig about to see whats going on.
It doesn't work in Embedded Python Console, but does work inside a script.
  1. Open Blender from a terminal (or click Window -> Toggle System Console)
  2. Open Text Editor -> New
  3. Paste import IPython; IPython.embed()
  4. Click Run Script (Alt P)
  5. IPython shell appears in the system console
  6. Type quit() when you want to go back to the Blender UI
Campbell Barton (campbellbarton) triaged this task as Confirmed, Low priority.Feb 1 2019, 11:49 AM
