Cycles CPU 25% load only during rendering #59874
6 Participants
Reference: blender/blender#59874
Operating system: Windows 10 pro
Graphics card: 1080ti
PC: AMD 2990WX, 4x16GB ram
Broken: 2.8 date: 2018-12-24 14:03
Hash:
6d89337257
the rendering uses 25% CPU load
auto-detect 64threads, or fixed 64, both same issue,
render output image size 19201028, tile size 1616, progresive rendering does not work - shows tile rendering
the problem does not occur in blender 2.79 - the load is close to 100% there.
many thanks,
Filip{F6078572}
Added subscriber: @filanek
Added subscriber: @JasonClarke
Added subscriber: @gsrb3d
https:*www.anandtech.com/show/13124/the-amd-threadripper-2990wx-and-2950x-review/2 says 2 dies have direct access, 2 do not. But all of them have caches (L3 being 8MB per CCX, 2 CCX per die) so while they will get a performance hit with the extra hop, they should not be 100% useless. https:*www.guru3d.com/articles-pages/amd-ryzen-threadripper-2990wx-review,4.html gives less than double time for the double hop case, noticeable but caches could hide part of the issue.
ce927e15e0
has special code for 2990WX and while comments talk about nodes 0 and 2 , function calls only use 0 (!?). Suspicously matches that you see 25% used, with 1 & 3 ignored on purpose, 2 not called.Maybe reverting that commit and testing could show if that is the culprit, and if running with all cores is worse than with half them. In that respect, you probably can try using OS tools to limit 2.79 to different dies (1 without direct RAM, 2 dies but one with the other without, etc) and compare the effects of RAM hops. The important will be seeing the variation in render times between only 2 dies with direct RAM to also using one or both of the indirect RAM dies.
Added subscribers: @Sergey, @ZedDB
@Sergey any input on this?
This is expected that only node 0 is used. This is explicitly mentioned in the comment in the code itself. This way job thread is likely to be on a node where .blend file data was read.
The commit referenced here is only affecting render preparation step (when data is being converted from Blender structures to Cycles). Path tracing is not affected by this (well, it is not supposed to anyway). Also, from my tests on Threadripper2 i had all cores occupied.
Does it happen with any file? Can it be seen, with, say, classroom or vector scenes from benchmark bundle?
just tested, see the attachment please{F6085707}
This issue was referenced by blender/cycles@e6901aaab0
826d7adde7
