Deleted entire folder with 10 saved files #59879
Reference: blender/blender#59879
Operating system: win10 64bit
Graphics card: Radeon RX 4600
Broken: blender-2.80.0{F6079579}
Did around 10 saves on a project. When starting a new season ( about 30 minutes after exiting the program, no system resets ) there are only 6 files seen and none are able to be started. The folder containing the project was wiped from hard drive. The program has no admin access. Only installed addons are filmic. sapling and export for unreal 4...
Other projects done until now work properly...
Added subscriber: @RR
It would be rally nice if there is a way to save the lost files, its a project for a 3d print birthday present...
This comment was removed by @RR
Name of the folder was changed to new folder and all the files are inside it but will not work with 2.8 or 2.79... The program starts and then crashes instantly...
Deleting the older version and then installing a new one, then dragging and dropping the file into it worked. Crash happens when i try to start the project with double clicking on blend file. Starting the latest work from list works. A few strange things happened. After dragging the newly renamed new folder (not renamed by me ) from its location to desktop, the contents of it ( 10 blender files ) mixed with an existing new folder containing only pictures. None of the files seem to be lost from either folder and when dragged, the system didnt seem to recognize that the folders were named the same and just combined them without asking if i wanted them overwritten... Files contained in this folder work, provided that they are started in the way described on the start of this comment...
Added subscriber: @brecht
Files saved in Blender 2.8 generally can't be opened in 2.79. If you double click files, they will be opened by 2.79 and as a result may crash. You indeed have to open them from inside Blender 2.8 to avoid that.
Further, if you rename folders Blender will not longer be able to find the files. That is also not a bug.
Further I can't see any bug for us to fix here. If you still think there is a bug, you need to provide exact steps for us to redo the problem, otherwise we can't investigate it.
Folder was renamed by blender, it was called ZaKevra and then it was renamed into new folder. Its location has not changed, it has not made any changes to number of files inside it. It was not able to recognize them even when started from inside the older version of 2.8. The problem was solved by deleting that version and adding a new one. To summarize:
The problem is that BLENDER RENAMED FOLDER by itself
Version used: blender-2.80-0fe5a789837-win64
Current version: blender-2.80-60b930af3e73-win64
We need steps to reproduce that problem, how you can get Blender to rename a folder by itself. Otherwise we can't investigate the problem. It's somewhat unlikely that Blender would have a bug like this and difficult to guess how it might happen if it does.
I think that the original bug occurred when i went from modeling to sculpt window and from texturing to modeling window. After these the engine (eevee) didnt also seem to recognize the textures on the other mashes ( a wall with a picture on it that was used to recreate the model i was working on) Sorry i cant give any more info then that, i am puzzled as well. If you would like to inspect the files them self, give me the email and i will send them via wetransfer...
Added subscriber: @AcidZack
Absolutely unsure how to recreate this problem but I can confirm that it happened to me, and it was blender that did it, It randomly renamed my folder (thanks to this thread i found it, because I thought it had deleted it too) to "New Folder" and immediately crashed, this was while doing basic modeling in edit mode.
this was the December 27th version: blender-2.80.0- 0661bcba3210-windows64
Good, so i am not the only one! Uninstalling the old version and installing the new one did it for me. Also renamed the folder to its original name...
Added subscriber: @J_T
Same thing happened to me when switching to the shading tab, blender 2.8 suddenly crashed. I uninstalled blender 2.8 and some of my blend files and folders disappeared.
