Blender 2.8 command line #59929
Reference: blender/blender#59929
Operating system: Windows 10 64 bit
Graphics card: GeForce GTX 1060 6GB/PCIe/SSE2
blender-2.80-1fc75dbbceea-win64
Basically using the background argument returns "EXCEPTION_ACCESS_VIOLATION"
Added subscriber: @MaTcHo0o
Added subscriber: @brecht
Can you try the latest build?
1fc75dbbce
is from 9 days ago, and it may have been fixed since then.Yeah i tried this one "blender-2.80.0-git.a4e4d9f0ab89-windows64" same problem
Does it still crash when you run with factory settings?
Can you run with debugging to see if it prints any more info?
Ok it seems it worked with the "--factory-startup"
So did i mess up something ?
It means there is something in your configuration that is causing it to crash
If you go to this path in the file browser:
There will be a folder named "2.80". If you could zip that and attach it here, we can investigate what the problem is and try to fix it.
To work around the crash on your end, you can remove this folder (or move it out of the way if you want a backup).
Ok roger that will prepare the zip file and will send it here
here it is : 2.80.zip
Added subscriber: @mont29
Likely to be same issue as blender/blender-addons#59773? @MaTcHo0o please check that report and see whether you can fix your issue by disabling add-ons using 3DView drawing.
I disabled the "3D view MeasureIt" addon and it worked
I believe it's also using the gpu module
Yes it is, will merge with the other report, thanks. :)
Closed as duplicate of blender/blender-addons#59773
