View all Sequences doesn't show all sequences
Closed, ResolvedPublicBUG
NOTE: This is not a duplicate of T59951. They have different causes.
Operating system: Microsoft Windows 7 Ultimate, Version 6.1.7601, Service Pack 1, Build 7601
GPU: ASUS Strix Radeon Vega 64
CPU: Intel(R) Core(TM) i7-5960X
RAM: 32.0 GB
Full System Information: Here
Broken:
2.80, 29 December, 01:07:02 -7c438e5366b2-
Pressing home moves the view to the middle and zooms in, away from the strip.
Press Home
PS This is probably related to the fact that when trying to View all Sequences the zoom always shows (or tries to show) the Zero mark on the timeline.
Richard Antalik (ISS) lowered the priority of this task from 90 to 50.
Area viewed by view_all (home) operator has defaults:
min[0] = 0.0;          // X min
max[0] = EFRA + 1;     // X max
min[1] = 0.0;          // Y min
max[1] = 8.0;          // Y max
Then if boundary of any currently visible sequence is more/less then these defaults, highest value(+1 to right and up) is used
This area affects also scrollbar min/max range.
Should then default X range be discarded if there is any sequence visible?
I think, that Y range is pretty sensible here...
@Richard Antalik (ISS) Did you add this task to the commit by accident? The view is still not working correctly...
Richard Antalik (ISS) changed the task status from Resolved to Unknown Status.Aug 4 2019, 6:03 PM
Ah thanks, I overlooked that start should be moved...
@Richard Antalik (ISS) What should be the behaviour for the operator? I see three main options:
  1. Frame everything no matter where in the timeline
  2. Frame everything starting from 0 (what it does now)
  3. Frame everything starting from the start frame
It could also be a mix, for example using the start frame as min, unless there are strips left to it.
in this case operator uses boundbox_seq() to get used area, and minimum is wrong - should be min[0] = SFRA;
Possibly preview range start if used.
Richard Antalik (ISS) changed the subtype of this task from "Report" to "Bug".
