Shrink/Flatten broken
version: 2.80 (sub 39), branch: master, commit date: 2018-12-28 23:19, hash: 7c438e5366b2, type: Release
On Win10, Quadro K2000
Solidify Modifer and Shrink/Flatten broken
Add Suzanne, go to edit mode, select all vertices, press alt-s to shrink/flatten. Move mouse. The result will be unexpected.
I get the same result as 2.79. The difference is that 2.8 has even thickness on by default. Does this explain the result you're seeing?
This is not a bug, but due to Offset Even being enabled by default.
@Campbell Barton (campbellbarton):
Maybe worth reconsidering if Offset Even should be default or not?
This is the result with Suzanne:
For simple cases with things like a cube or a sphere, Offset Even produces nicer results though.
Changed default back to off (was left off because we can't ensure spikes wont happen) rBb01f2607a6717deafc96c07287202ab11c118737
