spin tool no automerge
Closed, InvalidPublic
Operating system:win 10
Graphics card: hd 630
Broken: 2.80
(example: 2.79b release)
no automerge at 360°, have to enter the value to have the automerge
William Reynish (billreynish) lowered the priority of this task from 90 to 30.Dec 30 2018, 4:07 PM
Can you provide exact steps to reproduce this issue?
It's not a bug.
It's a problem on how blender shows the numerical values in some places (like in spin tool), if you do the spin manually and you see 360°, there is a hidden decimal value that prevent the automerge, if you hit on it and delete this decimal, the automerge happens.
Well, here it works fine.
  • select a face
  • enable spin tool
  • rotate 360 degrees while holding ctrl to snap
  • enable Auto Merge
It works.
If it fails, please give a specific example of how? For me it seems to work just fine.
I think it will be better to have a little bit higher merge value and a setting for this to avoid it....decimal explanation is quite good for experts ^^
ok I will try later with ctrl again william but automerge should be enough. here is the exact situation around 2'30 quick pyramide using spin tool
(just total different thing but I just did this. integrated to blender it will be good for average users [[ https://www.youtube.com/watch?v=_PjB1KQTqSc&t=72s| fast hdr settings]]https://www.youtube.com/watch?v=_PjB1KQTqSc&t=72s
that's a shame that in nodegroups it's not possible to integrate parameters without entries, in input or output, as a directory path of an image node, or the setting in mapping node. I wanted to put all in a node to have the setting all together in the properties menu on the right)
-- (zgorg) added a comment.EditedJan 1 2019, 4:03 AM
so it will be good to indicate the snap in the information windows or a little text as press "ctrl to merge" as an information. like it's a tool I thought was really auto.
other point a possibility to select no tool would be a good point
@-- (zgorg):
I still don't see the issue. I tried to first rotate to 360 degs, enable Auto Merge and then change the steps value. It still works.
Please provide an exact list of steps to reproduce the issue.
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Unknown Status.Jan 15 2019, 12:50 PM
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
