Removing fcurves/animated transform channels does not work
Closed, ResolvedPublicBUG
Operating system: Win10
Graphics card: Gtx 980
Broken: latest 2.8 build
Removing fcurves by script or directly from the interface (right click on the transform channels > Clear Keyframes) does not work
  • Open the attached blend file
  • The armature object has keyframes on Loc, Rot, Scale. Click Run Script in the text editor to remove all scale keyframes or right click the Scale transform channels > Clear Keyframes
  • Go to another frame, try to change the scale value: it won't work, the scale keyframes are still there although they're removed from the action/fcurves editor views.
lucas veber (lucky3) renamed this task from Removing fcurves/animated transform channels do not work to Removing fcurves/animated transform channels does not work.Jan 2 2019, 8:57 PM
lucas veber (lucky3) created this task.
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to 30.Jan 24 2019, 5:47 PM
I can only reproduce this if I use your script. When you write "Clear Keyframes" do you mean "Delete channels?" I do not get and "Clear keyframes" option if I right click the X scale channel.
"Clear Keyframes" is in the contextual menu when right clicking the Scale transform in the property panel of the viewport:
It's basically an update problem, the update can be triggered for example by unlinking-relinking the action from the armature.
Sebastian Parborg (zeddb) raised the priority of this task from 30 to 50.
Ah, thought you meant in the dope sheet, my bad. ><
Most of this issue was already fixed it appears, I only fixed some missing refresh when using the Python API.
