Freestyle Not Render Animation Blender 2.8
Operating system: Windows 10
Graphics card: Nvidia GeForce GTX 1060 6GB
Broken: Blender 2.80 Beta 12-28-18
Blender Cycles
The animation of Freestyle sub-unit only rendered one frame and that one frame's freestyle strokes render were applied to the rest of the animation sequence.
  1. Open Application
  2. Check Freestyle in Scene Menu
  3. Animated Object
  4. Set Sequence In/Out
  5. In Output Menu, set file location
  6. In Output Menu, set file format to PNG{F6154860}, Compression at 0%, RGB, 16 Bit
  7. Click Render Animation from in the "Render" menu in toolbar.
  8. BOOM! Bug Found
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.
Cannot reproduce here.
Cycles is doing fine with freestyle here, Eevee should not work at all with freestyle (see T58669)
(also confused you have Render Animation button in the Render panel? -- In the Properties Editor? This should only be in the menus...)
Anyways, could you share your blendfile so we can have a look?
Marking as incomplete until we have that...
I apologize. I am using Blender Cycles.
As for the Render Panel, which I am used to saying, I meant to say the "Render Animation" under the "Render" menu in the toolbar.
Third, here is my Blender File.
Hopefully this is helpful.
I have edited the changes.
Andrew May (mayday1814) updated the task description. (Show Details)
Philipp Oeser (lichtwerk) raised the priority of this task from Needs Information from User to Confirmed, Medium.Jan 3 2019, 4:44 PM
