NodeWrangler: cannot load image sequence in compositor (jpeg & exr) #60130
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#60130
Operating system: WIN10
Graphics card: gtx1050 laptop
Broken: 2.80 Beta, 11f2c65128dc & 4d795cee4938
Worked: 2.79.1
Hello blendevs'! Here is one bug report:
It is not possible to load
But it is possible to load one single image.
I Love so much this new 2.80!!!
Added subscriber: @s.vlaminck
Added subscriber: @lichtwerk
I'm afraid we need a bit more information here (with the exact steps to reproduce):
Image Node
open withDetect Sequences
option?Marking as incomplete untile we have the required information...
Sorry for that.
To reproduce:
Go to compositor panel
SHIFT A, image sequence then A to select all.
Then, with node wrangler disactivated, image sequence disapear.
HOWEVER!
I just found that with and witout node wrangler, adding an image (and not an image sequence) works fine...
SO what is the shiftA/Input/image sequence option?
The
node wrangler
feature (shiftA/Input/image sequence
) is a bit more forgiving when it comes to naming of the sequences.[and thx for spotting that error -- happens when you dont have
Use Nodes
activated in Compositing editor.... will fix...]There is another error in the Node Wrangler addon that you will run into even if you have
Use Nodes
activated in Compositing editor (see #59962, will also fix shortly...)When these error are fixed, Node Wrangler is a bit more forgiving behavior when it comes to naming of the sequences, as stated above.
reg. the
Detect Sequences
option (shiftA/Input/image
): that will also try to detect sequences (but is not as forgiving), for example:Image
(blender + Detect Sequence) andImage Sequence
(node wrangler)Image
(blender + Detect Sequence) but works inImage Sequence
(node wrangler)Anyways, will confirm for now and fix the Node Wrangler errors...
You're welcome,
I really enjoy your work guys, and I am impressed how efficient you are!
cannot load image sequence in compositor (jpeg & exr)to NodeWrangler: cannot load image sequence in compositor (jpeg & exr)This issue was referenced by blender/blender@8b4e0eb88e
