UV Smart Project Becomes Dumb
Open, Needs TriagePublic
Operating system: Windows 10 Pro
Graphics card: nVidia RTX 2080
Broken: 2.80, 11f2c65128dc
(example: 2.79b release)
App displays error screen. See screenshot.
Press "u" for UV menu. Select "Smart Project." Click OK. WWIII begins and everybody dies.
Cannot reproduce here. Works perfectly in the latest 2.8 beta. Can you try with a newer build?
William Reynish (billreynish) triaged this task as Incomplete priority.Sat, Jan 5, 12:52 AM
Marking as incomplete until author has tested with newer build.
I can repro with today's git. Here are the steps
  • Open provided .blend
  • Select an empty spot on the viewport
    • At this point Circle.002 will still be 'active' but nothing will be 'selected'
  • Hit tab to go into Edit Mode (this is fine because of active)
  • Select all verts
  • Do the smart UV unwrap
This is a combination of the weird active/selected state + the operator's current implementation of only looking at selected
I can confirm that. i have the same problem.
Brecht Van Lommel (brecht) raised the priority of this task from Incomplete to Needs Triage.
