EEVEE shadow rendering errors #60205
Reference: blender/blender#60205
Operating system: Windows 10
Graphics card: GTX 1080 & 1050Ti
Broken: blender-2.80.0-git.a7c5f4f20657-windows64
Shadow computation error when rendering with EEVEE. When two polygons touch there is light bleed-through in the shading computation which should not exist.
Open default scene.
Delete nearest vertical faces of default cube.
Render with EEVEE using F12
Upper edge of left rear face of cube receives illumination where it should be in shadow. Leaking illumination around right rear face of cube. Odd hard-shadow artifact on lower face on front edge.
I suspect this is due to edges being evaluated in different directions during the render, so there is an apparent gap where there isn't actually one in the topology of the object.
Renders correctly in Cycles or Blender 2.79 "Bender Render"
Added subscriber: @butler
Added subscribers: @fclem, @ZedDB
Is this something that can be fixed @fclem ?
Added subscriber: @moisessalvador
Not a bug. Those are the limitations of real time z depth shadows, since they are not raytraced. Very common in videogames.
You can get better results, but not out of the box until you tweak some values, turn things on or off, and make a trade between performance and precision. Here are the things you can do:
I personally go for VSM, Shadow res = 2048 or higher, High bitdepth = on, Soft shadows = on, Softness = 0.3, Bias = 0, Bleed bias = 0.5, and Contact shadows = off, since they are screen space and weird with thin occluding objects
I'll close this then.
Added subscriber: @int-ua
I see a signinficant gap between shadow and objects where there should be none, is it the same problem? new.blend
Edit: here is a similar problem: https://blender.stackexchange.com/q/161979/1958
