Transforming a hidden object (hidden via Outliner>Eye-Icon) crashes Blender application
Operating system: Linux Ubuntu 18.04.1LTS
Graphics card: nvidia 1060 mobile
Note: see attached "system-info.txt" for further details
Broken:
Blender 2.80 Beta Date:2019-01-03 17:12 Hash: a30bdcc142f1 (as from Splashscreen)
Transforming/Moving/Scaling/Rotating an object, which has been hidden via the corresponding "eye" icon in the Outliner window, crashes Blender.
Bug is easy to consistently reproduce starting from the default scene:
  1. Start from the default scene that Blender presents you with when opened;
  2. Right-click mouse on the default cube object to select it;
  3. In the Outliner window click on the "eye" icon relative to the viewport-visibility of the default cube object, in such a way to have the cube hidden/invisible in the Viewport but still selected as from step 2.;
  4. With the default cube object hidden but still selected press "G" key to grab/translate the hidden object and drag the mouse to move the cube object to a new position;
  5. When you left-click mouse in order to confirm translation of the cube object to the new position Blender will crash/exit.
Notes: The same behavior happens both when you try to translate "G" or scale "S" the hidden object: Blender crashes on confirmation of the attempted transformation; if you try and rotate "R" the hidden object, then Blender crashes as soon as you drag the mouse to rotate, even before left or right mouse-clicking for confirmation/cancel of the operation.
system-info.txt
Related Objects
