missing UI elements.
Closed, DuplicatePublic
windows 10 64bit
Blender Version,
Date - 2019-01-07-00;16 Hash - 96f762500ef9 Branch - blender2.7
Missing UI elements for adding "transform orientations" and "pivot point" into the favourites menu, No option available for this.
Missing UI elements for adding rotational limits to rigid body constraints when constraint is of type "generic"... However generic spring has the correct options available.
Philipp Oeser (lichtwerk) lowered the priority of this task from Needs Triage by Developer to Normal.
Please only report one issue per report.
regarding Quick Favorites for pivot and orientations: this is basically the same issue as T59244
regarding Ridgid body generic constraint: will check...
regarding Ridgid body generic constraint: committed rBf2d2bafe8569 now.
Other issue I will merge into T59244...
