GPU Fault while rendering scenes with subsurface scattering using OpenCL #60300
Closed
opened 2019-01-08 02:44:53 +01:00 by Sergey · 10 comments
Operating system: Arch Linux, Ubuntu 18.04 LTS
Graphics card: Sapphire RX 590 Nitro+
Broken:
2.79 release (2c0c1f494d), 2.8 beta (266b1e2cdb)
I'm running arch linux, and recently I've got a new sapphire RX 590 Nitro+. On Arch Linux, I'm using an open source amdgpu driver, that's included in linux kernel, and opencl driver from amdgpu-pro package. On Ubuntu I'm using full official amdgpu-pro driver set.
On both occasions, rendering with OpenCL works fine, unless the scene contains objects with subsurface scattering (either subsurface scattering in principled BDSF, or a standalone node). In that case, after finishing OpenCL kernel compilation (which happens without any problems), my video output completely halts, and I have numerous "GPU fault" errors in my system journal (I've included full text as attachment in journalctl.txt). Blender terminal output doesn't produce any errors though.
At first, I thought it's a hardware or driver problem. I didn't find anything like this though. It only happens in blender, while trying to use subsurface node. Any other opencl uses (luxrender, phoronix test suite with juliagpu), as well as general benchmarks and stress tests of my graphics card are completely fine.
I tried using many combinations of older linux kernel versions (since it includes amdgpu driver) and related libraries (libdrm and amd opencl runtime). I also installed Ubuntu 18.04 and official proprietary amdgpu-pro driver set, but I had exactly the same problem, so I suspect it's a blender bug (and not related to my driver or kernel).
The problem doesn't occur if nodetree contains subsurface prior to opencl initialization, it's possible to make a new .blend, add principled bdsf and start rendering it, it will work until the first opencl kernel compilation, after which it crashes. On complex scenes though, it occurs anyway, even if I just opened the file and didn't change anything yet. There may be other cases when this problem occurs, but, unfortunately, trying to determine more causes is hard, since I need to hard-reset my computer every time.
I've tried various blender versions, including 2.77, 2.78, 2.79, latest stable 2.8 beta and latest nightly 2.8 build. On 2.77 and 2.78, it worked completely fine, due to missing opencl subsurface scattering implementation, and this shader was just black. On 2.79 and later, I experienced the problem described above.
I found a somewhat similar bug report, although it occurs in different conditions https://developer.blender.org/T57774.
I also included a "system-info.txt" file from my Arch Linux installation.
UPD: This bug was also reproduced on another system (arch linux) with Asus Strix r9 390 8G OC and amdgpu-pro opencl driver.
Using opencl with amdgpu-pro driver, with included .blend file, for me, this problem can be reproduced by enabling "rendered" viewport mode first, and then adding some amount of subsurface scattering in principled BDSF node in node editor.
test.blend
system-info.txt
journalctl.txt
**System Information** Operating system: Arch Linux, Ubuntu 18.04 LTS Graphics card: Sapphire RX 590 Nitro+ **Blender Version** Broken: 2.79 release (2c0c1f494dcf), 2.8 beta (266b1e2cdbc1) **Short description of error** I'm running arch linux, and recently I've got a new sapphire RX 590 Nitro+. On Arch Linux, I'm using an open source amdgpu driver, that's included in linux kernel, and opencl driver from amdgpu-pro package. On Ubuntu I'm using full official amdgpu-pro driver set. On both occasions, rendering with OpenCL works fine, unless the scene contains objects with subsurface scattering (either subsurface scattering in principled BDSF, or a standalone node). In that case, after finishing OpenCL kernel compilation (which happens without any problems), my video output completely halts, and I have numerous "GPU fault" errors in my system journal (I've included full text as attachment in journalctl.txt). Blender terminal output doesn't produce any errors though. At first, I thought it's a hardware or driver problem. I didn't find anything like this though. It only happens in blender, while trying to use subsurface node. Any other opencl uses (luxrender, phoronix test suite with juliagpu), as well as general benchmarks and stress tests of my graphics card are completely fine. I tried using many combinations of older linux kernel versions (since it includes amdgpu driver) and related libraries (libdrm and amd opencl runtime). I also installed Ubuntu 18.04 and official proprietary amdgpu-pro driver set, but I had exactly the same problem, so I suspect it's a blender bug (and not related to my driver or kernel). The problem doesn't occur if nodetree contains subsurface prior to opencl initialization, it's possible to make a new .blend, add principled bdsf and start rendering it, it will work until the first opencl kernel compilation, after which it crashes. On complex scenes though, it occurs anyway, even if I just opened the file and didn't change anything yet. There may be other cases when this problem occurs, but, unfortunately, trying to determine more causes is hard, since I need to hard-reset my computer every time. I've tried various blender versions, including 2.77, 2.78, 2.79, latest stable 2.8 beta and latest nightly 2.8 build. On 2.77 and 2.78, it worked completely fine, due to missing opencl subsurface scattering implementation, and this shader was just black. On 2.79 and later, I experienced the problem described above. I found a somewhat similar bug report, although it occurs in different conditions https://developer.blender.org/T57774. I also included a "system-info.txt" file from my Arch Linux installation. UPD: This bug was also reproduced on another system (arch linux) with Asus Strix r9 390 8G OC and amdgpu-pro opencl driver. **Exact steps for others to reproduce the error** Using opencl with amdgpu-pro driver, with included .blend file, for me, this problem can be reproduced by enabling "rendered" viewport mode first, and then adding some amount of subsurface scattering in principled BDSF node in node editor. [test.blend](https://archive.blender.org/developer/F6215317/test.blend) [system-info.txt](https://archive.blender.org/developer/F6215320/system-info.txt) [journalctl.txt](https://archive.blender.org/developer/F6215321/journalctl.txt)
Author
Added subscriber: @ClockGen
This issue was referenced by blender/cycles@cd5b943965
This issue was referenced by blender/cycles@cd5b94396584cadfae5ed4d9c3f9e3d2063dfb1f
This issue was referenced by 8491dba0c6
This issue was referenced by 8491dba0c6bb96f9785e27429c72315ba9660511
Author
I've tested latest experimental builds for 2.79 and 2.80, but the problem still persists.
Author
Changed status from 'Resolved' to: 'Open'
Sergey reopened this issue 2019-01-09 14:05:30 +01:00
This issue was referenced by blender/cycles@761d23db6c
This issue was referenced by blender/cycles@761d23db6c7ce8e14014864e5e9fba32838320a2
This issue was referenced by b7fb3296c1
This issue was referenced by b7fb3296c101bf408455352ec9784a8870672c81
Author
Tested with nightly 2.79 and 2.80, everything seems to work fine.
Reference: blender/blender#60300
