Save Render Shortcut Not Working
Operating system: WIn 10 64Bit
Graphics card: Geforce GTX 970M
Broken:(example: 2.80, blender2.8, 2019-01-07)
Issue 1.
Save render image shortcut (F3) is gone… and although the drop down menu is showing (ctrl+s) as the shortcut, using it just open the save .blend file window. So saving saving a rendered image without any mouse click (shortcut F3) in 2.79x has been replaced by two cumbersome mouse clicks in 2.80!
It would be very helpful to have an easy to use default shortcut for saving rendered images quickly.
Issue 2.
This is not as big an issue… but why open an additional render window (even in the render workspace) and clutter the workflow? If there is a reason behind it I would love to understand. Can this window be disabled**
Brecht Van Lommel (brecht) closed this task as Archived.Jan 9 2019, 7:28 PM
I don't see a bug here:
  • The shortcut shows as Shift+S and that one works, it's not Ctrl+S.
  • The default is now to open a new window, you can change this in Render menu > Display Mode.
Making it use the Rendering workspace would be good, but this is not supported yet.
Saikat (skt) removed Brecht Van Lommel (brecht) as the assignee of this task.Jan 9 2019, 7:28 PM
Saikat (skt) reopened this task as Open.
Saikat (skt) edited projects, added BF Blender: 2.8; removed BF Blender.
Brecht Van Lommel (brecht) closed this task as Archived.Jan 9 2019, 7:29 PM
Brecht Van Lommel (brecht) edited projects, added BF Blender; removed BF Blender: 2.8.
