Pie Menu: 3D Viewport Pie Menus keep making new keybinds when activating them #60403
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#60403
Operating system: Windows 10 and 7 (two computers)
Graphics card: Geforce GTX 980 and 1060 respectively.
Broken: 2.80, hash: 96f762500ef9, 2019-01-07 00:16
Was working on my custom keybinds and I wanted to add the pie menus into my workflow. However, because some of them are add-ons, they automatically added the old keybinds into my settings, which messed up a bunch of my keys from working like they should (i.e. thetool menu I hotkeyed to Q stopped working and was instead showing the view numpad pie: hotkey Q add-on)
The only solution I have found is to manually remove the keybinds that the add-on automatically adds, but it is a very tedious process that I have to repeat every time I download and install a new, clean version of Blender. I would prefer if you could just deactivate automatic add-on keybinds with a button so you don't have to remove them yourself.
Blender 2.8 keybinds customized.pdf
Blender 2.8 Keybindings.py
Added subscriber: @Frozen_Death_Knight
Added subscriber: @BrendonMurphy
hi, Addons are specifically designed to interfere as little as possible with Blender default keymaps. They are also iirc, loaded at start up. You are using custom keymaps which can fall outside the scope of addons design and default key mappings at the moment. I feel that what you are requesting is outside of addons/keymap current design. To get around this you can edit the individual files that give you trouble with your custom keymap. I'm not sure this is a bug or a feature request or simply a limitation of the current design and the way things work.
A more knowledgeable blender developer may correct me if I'm wrong here.
Seems like more of a fairly big oversight to design automatic keybinds without an easy way to change/remove them when it is fully within reason for a user to want to change keybinds if they so desire, even in the older versions of Blender. Besides, the 2.8 beta is already in the middle of changing the keybinds and menus to accommodate users from other 3D software by adding L click select as a default option and more, so I disagree that it is outside of the current design, especially when said design is constantly changing. Also, I have been changing them manually, which is why this thread exists to begin with, to possibly get a proper fix to the problem. As for it being a bug or a feature, my guess is that it was intentionally designed that way, but it is a feature with consequences and is making a problem.
Added subscriber: @SimHacker
hi,
e66bf5191f
should fix this issue. I've checked that the addons keymaps are removed correctly. In the end I was able to reproduce your issue with load factory settings giving an error.Thanks for taking a look at the issue! I truly appreciate it! :)
