Using subdiv modifier affects normal baking performace of all objects in scene #60428
8 Participants
Reference: blender/blender#60428
Operating system: Windows 10
Graphics card: GTX 1080Ti
Broken: version: 2.83 (sub 10), branch: master, commit date: 2020-03-19 11:11, hash:
cc516b82ef
Worked: Never (2.8+)
#60428.blend
Remove subsurf modifier on
door_frame_low.001
object and repeat step 2Baking is much quicker and doesn't require too much RAM
Added subscriber: @JonathanLampel-4
Baking normals many times freezes computerto Baking memory usage massively increases over timeAdded subscriber: @ZedDB
There is something weird going in in there for certain. If I delete the door_high and door_low collections the baking is fine.
However, as those objects shouldn't affect the baking this is a bit odd.
Added subscriber: @LeighAlexH
I'm currently following Jonathan's door tutorial and experiencing the exact same issue in 2.80.45. 42.25GB memory usage and about half an hour for a very simple bake.
Added subscriber: @dfelinto
Added subscriber: @dr.sybren
Changed status from 'Confirmed' to: 'Needs User Info'
I can't reproduce this issue with the example file. When I click 'bake' I get this error:
Adding a new image and selecting that in the 'cube normal' node fixes that, though. I've updated the blend file in the task description for this.
I can also confirm the long duration (waited minutes, is still at 0%) and the memory usage. I cancelled after Blender allocating 32 GB.
Disabling the two hidden collections indeed works around this.
@JonathanLampel-4 can you do more digging? If you can, please remove objects one by one to see which one is influencing this behaviour.
Sure thing! Thanks for updating the file for 2.81. Here's what I've found in an afternoon of investigating.
There is no one object that causes the slowdown - each object seems to contribute a little bit, but some disproportionately more than others.
Turning on Simplify and setting Max Subdiv to 0 for Render helps substantially. However, it can't be just the subdiv modifier since some objects with no subdiv modifier still cause a smaller but noticeable spike in memory.
Turning on Simplify and setting Max Subdiv to 0 speeds things up even for the problematic objects that don't have a Subdiv modifier, which is very strange.
The relationship between number of problematic objects and the size of the memory spike is not linear. I would have assumed that including ten problematic objects would result in a much bigger spike than including only one problematic object, but that doesn't seem to be the case.
Here's an updated file that has all the objects organized by how much they contribute to the memory spike. It may be useful to know that all of these objects have been part of several bakes before in this file's history. Totally new objects, even very dense ones, don't seem to influence the bake whatsoever.
baking-bug_02.blend
I really appreciate you looking into this one! This type of major slowdown has happened to me on every project in the past year and a half in which I need to bake normals for a lot of objects, and it doesn't show up until well into production. If there's any other digging you would find useful, just let me know.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @ankitm
If the memory trace (Instruments.app) helps. This is for the ~800MB jump in allocations.
This is for ~500MB jump at a later point.
Baking memory usage massively increases over timeto Using subdiv modifier affects normal baking performace of all objects in sceneChanged status from 'Needs Developer To Reproduce' to: 'Confirmed'
