Missing/broken Armature, particles not rendering properly in cycles
Closed, InvalidPublic
Operating system: Windows 10
Graphics card: Nvidia GeForce 1080
Broken: 2.80, 2019-01-11
The armature doesn't show up anymore despite being set to visible and all bone Layers being active.
The original instances of the objects that are emitted from the particle systems in the scene are rendered despite being set to "not visible". If you disable the original instances of the particles for rendering, the emitted objects won't be rendered as well. So there is no way of having objects/collections being emitted without their original instances showing up as well.
I have no idea how that error with the armature occured, but for the particle error just create a particle system that emits an object/collection and then try to find a way to render out the particles without rendering the original instance of the emitted object/collection.
Sebastian Parborg (zeddb) claimed this task.
The armature doesn't show up because you are in local view (toggle it with numpad / or in the View drop down menu).
For the particles, you simply create a new scene and move the collection of the emitted objects over to that scene. (You can create new scenes and the top right)
