weird outline bug
Operating system: Ubuntu 18.04
Graphics card: Nvidia GTX 750Ti
Resolution: 1600*900
Broken: 2.80 6439ed844e78 2018-01-12
when rotating camera the orange outline behaves really weird, so it's either hidden or can be seen for like 200ms and then disappears, with some right angles i can actually see outline
also outline goes berserk when zooming in (https://imgur.com/a/ebQoVuB)
Based on the default startup;
just rotate/zoom camera
Jacques Lucke (JacquesLucke) triaged this task as Needs Information from User priority.
Please upload images/gifs directly here instead of linking to an external site.
Are your drivers up to date?
Can you start Blender from the terminal using the --debug --debug-gpu options and post the output here?
Switching to fully guarded memory allocator.
Blender 2.80 (sub 40)
Build: 2019-01-11 00:23:58 Linux Release
argv[0] = ./blender
argv[1] = --debug
argv[2] = --debug-gpu
/run/user/1000/gvfs/ non-existent directory
read file
Version 280 sub 39 date unknown hash unknown
GPUTexture: create : TEXTURE_CUBE_MAP, RGBA16F, w : 2, h : 2, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 1, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
found bundled python: /home/i1qwert/Desktop/blender-2.80-6439ed844e78-linux-glibc224-x86_64/2.80/python
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1115, h : 26, d : 0, comp : 4, size : 0.11 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 128, d : 0, comp : 1, size : 2.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 405, h : 26, d : 0, comp : 4, size : 0.04 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 16, h : 32, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1488, h : 32, d : 0, comp : 4, size : 0.18 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1520, h : 20, d : 0, comp : 4, size : 0.12 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 263, h : 26, d : 0, comp : 4, size : 0.03 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 29, h : 475, d : 0, comp : 4, size : 0.05 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 234, h : 475, d : 0, comp : 4, size : 0.42 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 263, h : 212, d : 0, comp : 4, size : 0.21 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1256, h : 26, d : 0, comp : 4, size : 0.12 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1256, h : 30, d : 0, comp : 4, size : 0.14 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 56, h : 657, d : 0, comp : 4, size : 0.14 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1256, h : 683, d : 0, comp : 4, size : 3.27 MiB
GPUTexture: create : TEXTURE_2D, DEPTH24_STENCIL8, w : 1256, h : 683, d : 0, comp : 1, size : 3.27 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 257, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 256, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1256, h : 683, d : 0, comp : 3, size : 3.27 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 1256, h : 683, d : 0, comp : 1, size : 3.27 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1256, h : 683, d : 0, comp : 2, size : 3.27 MiB
GPUTexture: create : TEXTURE_2D, RGB16F, w : 64, h : 64, d : 0, comp : 3, size : 0.05 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 1256, h : 683, d : 0, comp : 1, size : 2.45 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 1256, h : 683, d : 0, comp : 1, size : 1.64 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 16, h : 16, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 64, d : 0, comp : 1, size : 1.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 527, h : 494, d : 0, comp : 4, size : 0.99 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 388, h : 32, d : 0, comp : 4, size : 0.05 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1116, h : 32, d : 0, comp : 4, size : 0.14 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1195, h : 26, d : 0, comp : 4, size : 0.12 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1196, h : 32, d : 0, comp : 4, size : 0.15 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1600, h : 20, d : 0, comp : 4, size : 0.12 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 277, h : 26, d : 0, comp : 4, size : 0.03 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 29, h : 485, d : 0, comp : 4, size : 0.05 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 248, h : 485, d : 0, comp : 4, size : 0.46 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 277, h : 217, d : 0, comp : 4, size : 0.23 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1322, h : 26, d : 0, comp : 4, size : 0.13 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1322, h : 31, d : 0, comp : 4, size : 0.16 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 56, h : 671, d : 0, comp : 4, size : 0.14 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1322, h : 697, d : 0, comp : 4, size : 3.51 MiB
GPUTexture: create : TEXTURE_2D, DEPTH24_STENCIL8, w : 1322, h : 697, d : 0, comp : 1, size : 3.51 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1322, h : 697, d : 0, comp : 3, size : 3.51 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 1322, h : 697, d : 0, comp : 1, size : 3.51 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1322, h : 697, d : 0, comp : 2, size : 3.51 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 1322, h : 697, d : 0, comp : 1, size : 2.64 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 1322, h : 697, d : 0, comp : 1, size : 1.76 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 28, h : 28, d : 0, comp : 1, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 180, h : 32, d : 0, comp : 4, size : 0.02 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1032, h : 32, d : 0, comp : 4, size : 0.13 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 407, h : 125, d : 0, comp : 4, size : 0.19 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 525, h : 108, d : 0, comp : 4, size : 0.22 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 147, h : 72, d : 0, comp : 4, size : 0.04 MiB
Saved session recovery to '/tmp/quit.blend'
Blender quit
Jacques Lucke (JacquesLucke) raised the priority of this task from Needs Information from User to Needs Triage by Developer.
Does this happen if you have the latest nvidia driver (410.93)?
It is available here:
https://www.nvidia.com/Download/driverResults.aspx/141700/en-us ?
But you should probably look up the recommened way of installing it for ubuntu first.
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.Jan 28 2019, 11:38 AM
Jacques Lucke (JacquesLucke) claimed this task.
