I get " Invalid Drive: :J\ when I try to run Blender
Operating system: Windows 10
Graphics card:On Board
Blender Version 2.79b
Broken:2.79b
(example: 2.79b release)
Short description of error I get " Invalid Drive: :J\ when I try to run Blender
Brecht Van Lommel (brecht) triaged this task as Needs Information from User priority.
  • Can you post a screenshot of the error popup? It's not clear what exactly could give such an error.
  • Do you have a J:\ drive, and if so what kind of drive is it? Regular hard driver, USB, network, .. ?
There is no other information other than the "Invalid Drive: J:\"
I am trying to load the program on my "C:\" drive but it always gives the same message.
I do not have a ":J" drive.
Brecht Van Lommel (brecht) closed this task as Archived.EditedJan 14 2019, 6:26 AM
If I understand correctly, you are getting this error when running the Blender installer?
This seems to be point something being misconfigured in Windows itself, where trying to install many software packages will give the same error.
I'm not familiar with this problem myself, but a quick search seems to suggest fixing it like this:
https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed
Some more examples of similar errors.
https://answers.microsoft.com/en-us/windows/forum/windows_10-hardware/problem-directory-name-invalid-e-j/46b81ad3-35b2-4643-a8e8-2b3efa472bb7
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Error-1327-Invalid-Drive-when-starting-install.html
https://helpx.adobe.com/creative-suite/kb/error-1327-invalid-drive-drive.html
I don't think there is a bug in Blender here, this is not something we can solve for you.
