Static Overrides: Unpredictable crash on entering pose mode.
Closed, InvalidPublic
Operating system: Manjaro 18.0.1 Illyria / x86_64 Linux 4.14.90-1-MANJARO
Graphics card: Nvidia 1080 Ti
Broken: 2.80 (sub 40), branch: blender2.7, commit date: 2019-01-10 23:53, hash: 6439ed844e78
Worked: Uknown
After executing the "Make Static Override" operator on a linked armature, blender crashes upon entering pose mode.
Start Blender with --enable-static-override.
Delete all default objects for an empty scene.
From File select Link, open the Brow-Particles.blend file and select Brow and biped_blenrig in the Objects folder.
Upon successful linking, select the armature and from the search menu, type and select "Make Static Override".
Enter pose mode and Blender crashes!
Notes:
The linked mesh (Brow) which is deformed by the armature has vertex groups and combed hair particles.
I initially thought the issue is related to the hair system alone, but was able to successfully link and override another object with combed hair. So I wasn't able to fully isolate the crash to the hair system.
I have summarized my results based on three different file, with and without hair particles below.
Brow-Particles.blend => After linking and statically overriding Blender does crash.
Brow-NoParticles.blend => After linking and statically overriding Blender does not crash.
Mannequin-Hair.blend = > After linking and statically overriding Blender does not crash.
Mannequin blend by SebastL
hsab (hsab) updated the task description. (Show Details)
I'm getting this assert when linking:
BLI_assert failed: blender/source/blender/blenlib/intern/BLI_ghash.c:466, ghash_insert_ex(), at '(gh->flag & GHASH_FLAG_ALLOW_DUPES) || (BLI_ghash_haskey(gh, key) == 0)'
If is side step that assert, I get this backtrace when entering pose mode:
Thread 1 "blender" received signal SIGSEGV, Segmentation fault.
0x00007ffff4606756 in __strlen_sse2 () from /lib64/libc.so.6
(gdb) bt
#0  0x00007ffff4606756 in __strlen_sse2 () from /lib64/libc.so.6
#1  0x00005555582f780f in ShapeKey_name_length (ptr=0x7ffffffcdf20)
    at /home/zed/programmering/blender_master/blender/build/source/blender/makesrna/intern/rna_key_gen.c:329
#2  0x000055555827b236 in RNA_property_string_length (ptr=0x7ffffffcdf20, prop=0x55555d520a80 <rna_ShapeKey_name>)
    at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_access.c:3293
#3  0x000055555827b006 in RNA_property_string_get_alloc (ptr=0x7ffffffcdf20, prop=0x55555d520a80 <rna_ShapeKey_name>,
    fixedbuf=0x7ffffffcbcd0 "p\335\374\377\377\177", fixedlen=4096, r_len=0x7ffffffcbca8)
    at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_access.c:3247
#4  0x00005555583d1d3b in rna_property_override_diff_propptr_validate_diffing (propptr_a=0x7ffffffcdf20, propptr_b=0x7ffffffcdfb0, no_prop_name=false,
    r_is_id=0x7ffffffcdd62, r_is_null=0x7ffffffcdd63, r_is_type_diff=0x7ffffffcdd64, r_propname_a=0x0,
    propname_a_buff=0x7ffffffcbcd0 "p\335\374\377\377\177", propname_a_buff_size=4096, r_propname_b=0x0, propname_b_buff=0x0, propname_b_buff_size=0)
    at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_rna.c:1166
#5  0x00005555583d1fab in rna_property_override_diff_propptr (bmain=0x7ffff004cd08, propptr_a=0x7ffffffcdf20, propptr_b=0x7ffffffcdfb0, mode=RNA_EQ_STRICT,
    no_ownership=false, no_prop_name=false, override=0x7fffcf45d258,
    rna_path=0x7ffffffd53b0 "modifiers[\"ParticleSystem 1\"].particle_system.cloth.settings.rest_shape_key", flags=131072, r_override_changed=0x7ffffffd51ed)
    at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_rna.c:1219
#6  0x00005555583d2f7c in rna_property_override_diff_default (bmain=0x7ffff004cd08, ptr_a=0x7ffffffd75e0, ptr_b=0x7ffffffd7670,
    prop_a=0x55555d4b7c00 <rna_ClothSettings_rest_shape_key>, prop_b=0x55555d4b7c00 <rna_ClothSettings_rest_shape_key>, len_a=0, len_b=0, mode=0,
    override=0x7fffcf45d258, rna_path=0x7ffffffd53b0 "modifiers[\"ParticleSystem 1\"].particle_system.cloth.settings.rest_shape_key", flags=131072,
    r_override_changed=0x7ffffffd51ed) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_rna.c:1530
#7  0x0000555558287cd6 in rna_property_override_diff (bmain=0x7ffff004cd08, ptr_a=0x7ffffffd75e0, ptr_b=0x7ffffffd7670, prop=0x0,
    rna_path=0x7ffffffd53b0 "modifiers[\"ParticleSystem 1\"].particle_system.cloth.settings.rest_shape_key", mode=RNA_EQ_STRICT, override=0x7fffcf45d258,
    flags=131072, r_report_flags=0x7ffffffd52b0) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_access.c:7652
#8  0x0000555558288634 in RNA_struct_override_matches (bmain=0x7ffff004cd08, ptr_local=0x7ffffffd75e0, ptr_reference=0x7ffffffd7670,
    root_path=0x7ffffffdea70 "modifiers[\"ParticleSystem 1\"].particle_system.cloth.settings", override=0x7fffcf45d258, flags=RNA_OVERRIDE_COMPARE_RESTORE,
    r_report_flags=0x7ffffffd7428) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_access.c:7909
#9  0x00005555583d2115 in rna_property_override_diff_propptr (bmain=0x7ffff004cd08, propptr_a=0x7ffffffd75e0, propptr_b=0x7ffffffd7670, mode=RNA_EQ_STRICT,
    rna_path=0x7ffffffdea70 "modifiers[\"ParticleSystem 1\"].particle_system.cloth.settings", flags=131072, r_override_changed=0x7ffffffde8ad)
    at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_rna.c:1251
#10 0x00005555583d2f7c in rna_property_override_diff_default (bmain=0x7ffff004cd08, ptr_a=0x7ffffffe0ca0, ptr_b=0x7ffffffe0d30,
    prop_a=0x55555d5a8fe0 <rna_ClothModifier_settings>, prop_b=0x55555d5a8fe0 <rna_ClothModifier_settings>, len_a=0, len_b=0, mode=0,
    override=0x7fffcf45d258, rna_path=0x7ffffffdea70 "modifiers[\"ParticleSystem 1\"].particle_system.cloth.settings", flags=131072,
    r_override_changed=0x7ffffffde8ad) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_rna.c:1530
#11 0x0000555558287cd6 in rna_property_override_diff (bmain=0x7ffff004cd08, ptr_a=0x7ffffffe0ca0, ptr_b=0x7ffffffe0d30, prop=0x0,
    rna_path=0x7ffffffdea70 "modifiers[\"ParticleSystem 1\"].particle_system.cloth.settings", mode=RNA_EQ_STRICT, override=0x7fffcf45d258, flags=131072,
    r_report_flags=0x7ffffffde970) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_access.c:7652
#12 0x0000555558288634 in RNA_struct_override_matches (bmain=0x7ffff004cd08, ptr_local=0x7ffffffe0ca0, ptr_reference=0x7ffffffe0d30,
    root_path=0x7ffffffe8130 "modifiers[\"ParticleSystem 1\"].particle_system.cloth", override=0x7fffcf45d258, flags=RNA_OVERRIDE_COMPARE_RESTORE,
    r_report_flags=0x7ffffffe0ae8) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_access.c:7909
#13 0x00005555583d2115 in rna_property_override_diff_propptr (bmain=0x7ffff004cd08, propptr_a=0x7ffffffe0ca0, propptr_b=0x7ffffffe0d30, mode=RNA_EQ_STRICT,
    no_ownership=false, no_prop_name=false, override=0x7fffcf45d258, rna_path=0x7ffffffe8130 "modifiers[\"ParticleSystem 1\"].particle_system.cloth",
    flags=131072, r_override_changed=0x7ffffffe7f6d) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_rna.c:1251
#14 0x00005555583d2f7c in rna_property_override_diff_default (bmain=0x7ffff004cd08, ptr_a=0x7ffffffea360, ptr_b=0x7ffffffea3f0,
    prop_a=0x55555d68ee20 <rna_ParticleSystem_cloth>, prop_b=0x55555d68ee20 <rna_ParticleSystem_cloth>, len_a=0, len_b=0, mode=0, override=0x7fffcf45d258,
--Type <RET> for more, q to quit, c to continue without paging--
    rna_path=0x7ffffffe8130 "modifiers[\"ParticleSystem 1\"].particle_system.cloth", flags=131072, r_override_changed=0x7ffffffe7f6d)
#15 0x0000555558287cd6 in rna_property_override_diff (bmain=0x7ffff004cd08, ptr_a=0x7ffffffea360, ptr_b=0x7ffffffea3f0, prop=0x0,
    rna_path=0x7ffffffe8130 "modifiers[\"ParticleSystem 1\"].particle_system.cloth", mode=RNA_EQ_STRICT, override=0x7fffcf45d258, flags=131072,
    r_report_flags=0x7ffffffe8030) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_access.c:7652
#16 0x0000555558288634 in RNA_struct_override_matches (bmain=0x7ffff004cd08, ptr_local=0x7ffffffea360, ptr_reference=0x7ffffffea3f0,
    root_path=0x7fffffff17f0 "modifiers[\"ParticleSystem 1\"].particle_system", override=0x7fffcf45d258, flags=RNA_OVERRIDE_COMPARE_RESTORE,
    r_report_flags=0x7ffffffea1a8) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_access.c:7909
#17 0x00005555583d2115 in rna_property_override_diff_propptr (bmain=0x7ffff004cd08, propptr_a=0x7ffffffea360, propptr_b=0x7ffffffea3f0, mode=RNA_EQ_STRICT,
    no_ownership=false, no_prop_name=false, override=0x7fffcf45d258, rna_path=0x7fffffff17f0 "modifiers[\"ParticleSystem 1\"].particle_system", flags=131072,
    r_override_changed=0x7fffffff162d) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_rna.c:1251
#18 0x00005555583d2f7c in rna_property_override_diff_default (bmain=0x7ffff004cd08, ptr_a=0x7fffffff3a88, ptr_b=0x7fffffff3b18,
    prop_a=0x55555d5a6d80 <rna_ParticleSystemModifier_particle_system>, prop_b=0x55555d5a6d80 <rna_ParticleSystemModifier_particle_system>, len_a=0, len_b=0,
    mode=0, override=0x7fffcf45d258, rna_path=0x7fffffff17f0 "modifiers[\"ParticleSystem 1\"].particle_system", flags=131072,
    r_override_changed=0x7fffffff162d) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_rna.c:1530
#19 0x0000555558287cd6 in rna_property_override_diff (bmain=0x7ffff004cd08, ptr_a=0x7fffffff3a88, ptr_b=0x7fffffff3b18, prop=0x0,
    rna_path=0x7fffffff17f0 "modifiers[\"ParticleSystem 1\"].particle_system", mode=RNA_EQ_STRICT, override=0x7fffcf45d258, flags=196608,
    r_report_flags=0x7fffffff16f0) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_access.c:7652
#20 0x0000555558288634 in RNA_struct_override_matches (bmain=0x7ffff004cd08, ptr_local=0x7fffffff3a88, ptr_reference=0x7fffffff3b18,
    root_path=0x7fffffff6c40 "modifiers[\"ParticleSystem 1\"]", override=0x7fffcf45d258, flags=(RNA_OVERRIDE_COMPARE_CREATE | RNA_OVERRIDE_COMPARE_RESTORE),
    r_report_flags=0x7fffffff3868) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_access.c:7909
#21 0x00005555583d2115 in rna_property_override_diff_propptr (bmain=0x7ffff004cd08, propptr_a=0x7fffffff3a88, propptr_b=0x7fffffff3b18, mode=RNA_EQ_STRICT,
    no_ownership=false, no_prop_name=false, override=0x7fffcf45d258, rna_path=0x7fffffff6c40 "modifiers[\"ParticleSystem 1\"]", flags=196608,
    r_override_changed=0x7fffffffaced) at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_rna.c:1251
#22 0x00005555583d3541 in rna_property_override_diff_default (bmain=0x7ffff004cd08, ptr_a=0x7fffffffcf10, ptr_b=0x7fffffffcf30,
    prop_a=0x55555d66bf80 <rna_Object_modifiers>, prop_b=0x55555d66bf80 <rna_Object_modifiers>, len_a=0, len_b=0, mode=0, override=0x7fffcf45d258,
    rna_path=0x7fffcfa686e8 "modifiers", flags=196608, r_override_changed=0x7fffffffaced)
    at /home/zed/programmering/blender_master/blender/source/blender/makesrna/intern/rna_rna.c:1681
#23 0x0000555558287cd6 in rna_property_override_diff (bmain=0x7ffff004cd08, ptr_a=0x7fffffffcf10, ptr_b=0x7fffffffcf30, prop=0x0,
    prop_a=0x55555d66bf80 <rna_Object_modifiers>, prop_b=0x55555d66bf80 <rna_Object_modifiers>, rna_path=0x7fffcfa686e8 "modifiers", mode=RNA_EQ_STRICT,
    override=0x7fffcf45d258, flags=196608, r_report_flags=0x7fffffffadb0)
#24 0x0000555558288634 in RNA_struct_override_matches (bmain=0x7ffff004cd08, ptr_local=0x7fffffffcf10, ptr_reference=0x7fffffffcf30, root_path=0x0,
    override=0x7fffcf45d258, flags=(RNA_OVERRIDE_COMPARE_CREATE | RNA_OVERRIDE_COMPARE_RESTORE), r_report_flags=0x7fffffffcf0c)
#25 0x000055555807bd10 in BKE_override_static_operations_create (bmain=0x7ffff004cd08, local=0x7fffcf7faa08, force_auto=false)
    at /home/zed/programmering/blender_master/blender/source/blender/blenkernel/intern/library_override.c:558
#26 0x000055555807beb9 in BKE_main_override_static_operations_create (bmain=0x7ffff004cd08, force_auto=false)
    at /home/zed/programmering/blender_master/blender/source/blender/blenkernel/intern/library_override.c:596
#27 0x0000555558208db9 in BKE_undosys_step_push_with_type (ustack=0x7ffff0020c18, C=0x7ffff0030288, name=0x55555bddafb3 "Toggle Pose Mode", ut=0x7fffef64ebe8)
    at /home/zed/programmering/blender_master/blender/source/blender/blenkernel/intern/undo_system.c:458
#28 0x000055555820912b in BKE_undosys_step_push (ustack=0x7ffff0020c18, C=0x7ffff0030288, name=0x55555bddafb3 "Toggle Pose Mode")
    at /home/zed/programmering/blender_master/blender/source/blender/blenkernel/intern/undo_system.c:520
#29 0x000055555712d862 in ED_undo_push (C=0x7ffff0030288, str=0x55555bddafb3 "Toggle Pose Mode")
    at /home/zed/programmering/blender_master/blender/source/blender/editors/undo/ed_undo.c:103
#30 0x000055555712df28 in ED_undo_push_op (C=0x7ffff0030288, op=0x7fffcc241748)
    at /home/zed/programmering/blender_master/blender/source/blender/editors/undo/ed_undo.c:250
#31 0x00005555570eaeb3 in wm_operator_finished (C=0x7ffff0030288, op=0x7fffcc241748, repeat=false, store=true)
    at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:888
#32 0x00005555570ec6ab in wm_operator_invoke (C=0x7ffff0030288, ot=0x7fffead007c8, event=0x0, properties=0x0, reports=0x0, poll_only=false,
    use_last_properties=true) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:1366
#33 0x00005555570ecb7c in wm_operator_call_internal (C=0x7ffff0030288, ot=0x7fffead007c8, properties=0x0, reports=0x0, context=7, poll_only=false, event=0x0)
    at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:1540
#34 0x00005555570ecd9f in WM_operator_name_call_ptr (C=0x7ffff0030288, ot=0x7fffead007c8, context=7, properties=0x0)
    at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:1588
#35 0x00005555575fb4f3 in ED_object_mode_toggle (C=0x7ffff0030288, mode=OB_MODE_POSE)
    at /home/zed/programmering/blender_master/blender/source/blender/editors/object/object_modes.c:174
#36 0x00005555575fa05a in object_mode_set_exec (C=0x7ffff0030288, op=0x7fffc9c72188)
    at /home/zed/programmering/blender_master/blender/source/blender/editors/object/object_edit.c:1356
#37 0x00005555570ec4df in wm_operator_invoke (C=0x7ffff0030288, ot=0x7fffead00288, event=0x7fffe9e7ff08, properties=0x7fffffffd610, reports=0x0,
    poll_only=false, use_last_properties=true) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:1343
#38 0x00005555570ecb7c in wm_operator_call_internal (C=0x7ffff0030288, ot=0x7fffead00288, properties=0x7fffffffd610, reports=0x0, context=1, poll_only=false,
    event=0x7fffe9e7ff08) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:1540
#39 0x00005555570ecd9f in WM_operator_name_call_ptr (C=0x7ffff0030288, ot=0x7fffead00288, context=1, properties=0x7fffffffd610)
#40 0x00005555574296ac in ui_apply_but_funcs_after (C=0x7ffff0030288)
    at /home/zed/programmering/blender_master/blender/source/blender/editors/interface/interface_handlers.c:776
#41 0x0000555557442286 in ui_handler_region_menu (C=0x7ffff0030288, event=0x7fffc9c07708, UNUSED_userdata=0x7fffca8b4408)
    at /home/zed/programmering/blender_master/blender/source/blender/editors/interface/interface_handlers.c:9854
#42 0x00005555570ea1ee in wm_handler_ui_call (C=0x7ffff0030288, handler=0x7fffc9c72248, event=0x7fffc9c07708, always_pass=0)
    at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:573
#43 0x00005555570eee97 in wm_handlers_do_intern (C=0x7ffff0030288, event=0x7fffc9c07708, handlers=0x7fffef561f20)
    at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:2385
#44 0x00005555570ef860 in wm_handlers_do (C=0x7ffff0030288, event=0x7fffc9c07708, handlers=0x7fffef561f20)
    at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:2618
#45 0x00005555570f0c17 in wm_event_do_handlers (C=0x7ffff0030288)
    at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm_event_system.c:3008
#46 0x00005555570e5885 in WM_main (C=0x7ffff0030288) at /home/zed/programmering/blender_master/blender/source/blender/windowmanager/intern/wm.c:425
#47 0x00005555570e016e in main (argc=2, argv=0x7fffffffdcd8) at /home/zed/programmering/blender_master/blender/source/creator/creator.c:520
Bastien Montagne (mont29) lowered the priority of this task from 50 to 30.Nov 8 2019, 10:54 AM
the assert/crash in debug builds is a corruption in the .blend file (there are two brushes called Eraser Point there for some reason, opening and saving that file will fix it).
Besides that, I cannot reproduce any crash currently, can you please check if issue is still there?
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Unknown Status.Nov 15 2019, 12:22 PM
