Blender 2.80 crashes on changing between windows.
Operating system: Windows 10 64 bits
Graphics card: Geforce GTX 1050
Two monitors
Broken: 2.80, 2826c2be545e2019-01-12 11:10 Last daily build
I'm working with two monitors and I'have a 2 windows of the same Blender project in each screen.
Sometimes when I switch between windows blender crash.
Open the given .blend and it will open 2 Blender windows.
First change to Edit mode using the pie menu pressing Tab.
Then click in a viewport in the secondary window and again cllick in the main window viewport
Jacques Lucke (JacquesLucke) triaged this task as Needs Information from User priority.Jan 14 2019, 12:36 PM
Cannot reproduce it.
Are your drivers up to date?
Can you start Blender from the console with the --debug --debug-gpu options and post the output here?
Hi.
I have just updated the gpu card drivers and the problem persists.
Here is a video with a demostration of the crash:
https://youtu.be/q3dN-eyGDTE
Sometimes if you click more than one time in the same screen, the error will not appear.
Enclosed is the output in debug and debug-gpu mode
Thanks for your time.
Jacques Lucke (JacquesLucke) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Jan 14 2019, 5:37 PM
I tried it in an Ubuntu 18.04 partition and I cannot reproduce it.
Can't reproduce on WIn10 x64 v1607, 2 monitors plugged into GTX 1070.
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.Jan 30 2019, 7:09 PM
@Nico Forteza (nicofo) what driver did you use on your ubuntu install? Was it the same version as on windows?
Jacques Lucke (JacquesLucke) claimed this task.
