Eevee reflection cubemap does not render metallic objects
Operating system: Windows 10
Graphics card: GTX 1070
Broken: 2.80, 7707bf203c0f, 2019-1-14
As you can see in the attached image, metallic objects appear black in the cubemap, even if screenspace reflections are enabled during baking.
  1. Add object with metallic material
  2. Add reflection probe
  3. bake cube map
  4. view cubemap
Philipp Oeser (lichtwerk) closed this task as Archived.Jan 15 2019, 9:53 AM
I think this is a known limitation of baked probes, see https://docs.blender.org/manual/en/dev/render/eevee/limitations.html#indirect-lighting
Eevee does not support “specular to diffuse” light bounces nor “specular to specular” light bounces. All specular lighting is turned off during baking.
For specular-specular you need to use SSR.
Will archive this report (unless @Clément Foucault (fclem) has anything to add?)
You can make the object appear diffuse in the reflections if you want, by using the light path node and a mix shader.
