Crashing Without Warning When Selecting Edges and While Filling with Polygon
Operating system: Windows 10
Graphics card: Asus 1080ti Turbo
Broken: 2.8, 84c06e996a7a, blender 2.8, 2019-01-14 19:48
(example: 2.79b release)
If you try to select that marked edges in the area at the attached image, it crashes. Also try to fill with polygon tool. You will see. Thanks.
Campbell Barton (campbellbarton) triaged this task as Needs Information from User priority.
Could you give exact steps to redo the error?
Can't redo this error either by pressing F or Shift-F (two kinds of fill).
Sorry Campbell, I can't give anything about my previous moves but as far as i remember was just extruding and scaling thats all. I was exactly repeating the process on this video in Blender Cloud. https://cloud.blender.org/p/blenderella/56040ecf044a2a00a515adaa
Now i exported mesh as .obj file and imported back, cleaned sharp edges and it seems ok for now. I will inform you if that thing happen again.
Philipp Oeser (lichtwerk) closed this task as Archived.
Will archive for now then (feel free to comment again if you have found a way to reproduce...)
