An object crashes versions of blender past 11f2c65128dc
Operating system: Windows 10 64 bit
Graphics card: GTX 1060 6 gigabyte (The old one)
Broken: Every version I've tried past the version in "worked"
Worked: 11f2c65128dc-windows64 2019-01-02
I was editing this mesh object as part of a more complex model, hit some unknown buttons, one of which started the animation counter playing, I press escape to stop it, and blender crashes. I'm not sure if this took place on the one that worked that I still had around or the newer one, but for whatever reason the older version (That has the old preferences menu, not sure if it matters) can open and edit it fine.
Open the blender (bug ish.blend) file, select the object, edit mode, select a single vertex with right click and blender crashes.
Marshall Dale Tavares (Phos) renamed this task from An object crashes versions of blender past to An object crashes versions of blender past 11f2c65128dc.
Jacques Lucke (JacquesLucke) triaged this task as Confirmed, Medium priority.Jan 16 2019, 12:49 PM
The error happens during selection.
__GI_raise(int sig) (/build/glibc-OTsEL5/glibc-2.27/sysdeps/unix/sysv/linux/raise.c:51)
__GI_abort() (/build/glibc-OTsEL5/glibc-2.27/stdlib/abort.c:79)
__assert_fail_base(const char * fmt, const char * assertion, const char * file, unsigned int line, const char * function) (/build/glibc-OTsEL5/glibc-2.27/assert/assert.c:92)
__GI___assert_fail(const char * assertion, const char * file, unsigned int line, const char * function) (/build/glibc-OTsEL5/glibc-2.27/assert/assert.c:101)
GPU_vertbuf_raw_step(GPUVertBufRaw * a) (/home/jacques/blender-git/blender/source/blender/gpu/GPU_vertex_buffer.h:108)
mesh_create_edit_select_id(MeshRenderData * rdata, GPUVertBuf * vbo_pos, GPUVertBuf * vbo_verts, GPUVertBuf * vbo_edges, GPUVertBuf * vbo_faces) (/home/jacques/blender-git/blender/source/blender/draw/intern/draw_cache_impl_mesh.c:2680)
DRW_mesh_batch_cache_create_requested(Object * ob, Mesh * me, const ToolSettings * ts, const _Bool is_paint_mode, const _Bool use_hide) (/home/jacques/blender-git/blender/source/blender/draw/intern/draw_cache_impl_mesh.c:5387)
draw_object_backbufsel(Depsgraph * depsgraph, Scene * scene, View3D * v3d, RegionView3D * rv3d, Object * ob, short select_mode) (/home/jacques/blender-git/blender/source/blender/editors/space_view3d/drawobject.c:296)
backdrawview3d(struct Depsgraph * depsgraph, Scene * scene, ARegion * ar, View3D * v3d, Object * obact, Object * obedit, short select_mode) (/home/jacques/blender-git/blender/source/blender/editors/space_view3d/view3d_draw_legacy.c:263)
ED_view3d_backbuf_validate_with_select_mode(ViewContext * vc, short select_mode) (/home/jacques/blender-git/blender/source/blender/editors/space_view3d/view3d_draw_legacy.c:303)
ED_view3d_backbuf_validate(ViewContext * vc) (/home/jacques/blender-git/blender/source/blender/editors/space_view3d/view3d_draw_legacy.c:309)
unified_findnearest(ViewContext * vc, Base ** bases, const uint bases_len, int * r_base_index, BMVert ** r_eve, BMEdge ** r_eed, BMFace ** r_efa) (/home/jacques/blender-git/blender/source/blender/editors/mesh/editmesh_select.c:1032)
EDBM_select_pick(bContext * C, const int * mval, _Bool extend, _Bool deselect, _Bool toggle) (/home/jacques/blender-git/blender/source/blender/editors/mesh/editmesh_select.c:2060)
view3d_select_exec(bContext * C, wmOperator * op) (/home/jacques/blender-git/blender/source/blender/editors/space_view3d/view3d_select.c:1959)
view3d_select_invoke(bContext * C, wmOperator * op, const wmEvent * event) (/home/jacques/blender-git/blender/source/blender/editors/space_view3d/view3d_select.c:1994)
wm_operator_invoke(bContext * C, wmOperatorType * ot, wmEvent * event, PointerRNA * properties, ReportList * reports, const _Bool poll_only, _Bool use_last_properties) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1327)
wm_operator_call_internal(bContext * C, wmOperatorType * ot, PointerRNA * properties, ReportList * reports, const short context, const _Bool poll_only, wmEvent * event) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1570)
WM_operator_call_py(bContext * C, wmOperatorType * ot, short context, PointerRNA * properties, ReportList * reports, const _Bool is_undo) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:1648)
pyop_call(PyObject * UNUSED_self, PyObject * args) (/home/jacques/blender-git/blender/source/blender/python/intern/bpy_operator.c:260)
_PyMethodDef_RawFastCallKeywords (Unknown Source:0)
_PyCFunction_FastCallKeywords (Unknown Source:0)
_PyEval_EvalFrameDefault (Unknown Source:0)
_PyEval_EvalCodeWithName (Unknown Source:0)
_PyFunction_FastCallDict (Unknown Source:0)
_PyObject_Call_Prepend (Unknown Source:0)
[Unknown/Just-In-Time compiled code] (Unknown Source:0)
_PyObject_FastCallKeywords (Unknown Source:0)
bpy_class_call(bContext * C, PointerRNA * ptr, FunctionRNA * func, ParameterList * parms) (/home/jacques/blender-git/blender/source/blender/python/intern/bpy_rna.c:7926)
rna_operator_invoke_cb(bContext * C, wmOperator * op, const wmEvent * event) (/home/jacques/blender-git/blender/source/blender/makesrna/intern/rna_wm.c:1285)
wm_handler_operator_call(bContext * C, ListBase * handlers, wmEventHandler * handler, wmEvent * event, PointerRNA * properties) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2045)
wm_handlers_do_intern(bContext * C, wmEvent * event, ListBase * handlers) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2347)
wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:2693)
wm_event_do_handlers(bContext * C) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm_event_system.c:3082)
WM_main(bContext * C) (/home/jacques/blender-git/blender/source/blender/windowmanager/intern/wm.c:427)
main(int argc, const char ** argv) (/home/jacques/blender-git/blender/source/creator/creator.c:523)
The use of raw_pos in mesh_create_edit_select_id is wrong. The GPU_vertbuf_raw_step function is called too often on that buffer.
