Boolean modifier breaks colour/uv attribute in shader #60552
7 Participants
Reference: blender/blender#60552
Operating system: Windows 10
Graphics card: RTX 2080
Broken: 2.80 beta (2019-01-12,
2826c2be54
)Short description of error
Applying a boolean modifier to an object causes the colour attribute to become black when the object is in object mode. When the object is in edit mode, the colour is shown appropriately.
Load the default start-up file.
Set the display mode to workbench.
Copy the default cube and move it so it partially overlaps the first cube.
Add a boolean modifier to the first cube with the second cube as boolean object.
Add a vertex colour to the first cube.
Set the colour to be red on the whole cube.
Add a material to the first cube that takes the colour attribute and passes it to an emission shader.
Note that in edit mode the cube displays red as expected. However, in object mode the cube displays black instead of red.
Note that disabling the boolean modifier will cause the cube to be displayed red as well.
boolean disables colour attribute.blend
Added subscriber: @Tober-1
#61967 was marked as duplicate of this issue
#61426 was marked as duplicate of this issue
#61370 was marked as duplicate of this issue
#61299 was marked as duplicate of this issue
Did this work in Blender 2.79?
Added subscriber: @WilliamReynish
I can't reproduce it here. It seems to work correctly, taking the correct vertex colors from the boolean object, which works correctly in materials too.
Added subscriber: @lichtwerk
yeah, you need to have VCols on both objects [both objects have the same material], otherwise these wont transfer over. Like so:
boolean disables colour attribute corrected.blend
Dont see a bug here, closing...
@WilliamReynish, does the file he uploaded work for you? I only see black when setting it to rendered view. When I disable the boolean modifier, it works as expected.
[EDIT] @lichtwerk, ah that makes sense. Thanks for the explanation.
Thank you for the quick explanation, Philipp.
Added subscriber: @ideasman42
will reopen, just talked to @ideasman42 on IRC and it seems it should not loose custom data layers (when they exist on one object but not the other...)
Added subscriber: @StephenLeger
It also breaks uv channels > 0,
Add 2 uvs chanels, 2nd one is black with modifier enabled.
Boolean modifier breaks colour attribute in shaderto Boolean modifier breaks colour/uv attribute in shaderAdded subscriber: @RobertWesseling
Added subscriber: @nt_brasil
Added subscribers: @billyand, @ZedDB, @Sergey
Closed as duplicate of #59304
