LookDev mode not changing colors of object #60611
5 Participants
Reference: blender/blender#60611
Operating system: macOS High Sierra 10.13.6
Graphics card: Intel HD Graphics 3000 384 MB
Broken: Blender 2.8, 2019-01-17
(example: 2.79b release)
(example: 2.80,
edbf15d3c0
, blender2.8, 2018-11-28, as found on the splash screen)Worked: (optional)
When selecting the LookDev mode, it’s slow to respond. Once in mode, object turns black. When trying to change color of object in the Material tab, The object fails to turn the color selected and remains black.
Default startup.
Added subscriber: @smwalton
Can you start Blender using a terminal with the
--debug --debug-gpu
options and post the output here?Added subscriber: @thefatbaron
JacquesLucke - I am seeing this myself. Here is my information:
Operating system: Mac OS 10.14.3
Graphics card: Intel UHD 630, Preferred EGPU: AMD Radeon RX580 (via Sonnet eGFX Breakaway box)
Broken: 2.80,
faa255c0a4
, 2019-02-15As smwalton said, changing the base color - or any other attribute - of a material does not change the object in LookDev or Rendered mode. I have found two workarounds: First, perform any action - even a simple 'move' - then undo the action. The material will now appear correctly. Second, I use the "Create New Material" button next to the Material's name field. This creates a new material, which displays correctly on the object in the viewport. I've captured the debug output requested above, as this seems to be the same problem.
Edit to attach correct log file. This shows changing the base color of the default cube in Render view (no effect), moving the cube, then undoing the move (color now visible).
debugOutput.txt
Added subscriber: @ZedDB
Can any of you guys check if this is still a problem with the latest OSX version?
This appears to be working in the latest OSX 2.8 Beta build.
