No devices listed in bpy.context.preferences.addons['cycles'].preferences.devices when running in background mode
Closed, DuplicatePublic
Hardware: ROG Zephyrus laptop
Operating system: Ubuntu 18.04
Graphics card: GeForce GTX 1070
Nvidia drivers version: 390.77
CUDA version: 9.1.85
Broken:
2.80 beta, 2757469824bb, blender2.8, 2019-01-18, downloaded from https://builder.blender.org/download/blender-2.80-2757469824bb-linux-glibc224-x86_64.tar.bz2
Worked:
2.79b release
When running Blender 2.8 from command line in background mode, it is not possible to activate any GPU devices for rendering because
bpy.context.preferences.addons['cycles'].preferences.devices is empty. The rendering will still proceed with CPU.
To debug this, I've come up with a short script:
The logic is adapted from https://developer.blender.org/T54099 and this same script has been tested to work in following environments:
  • Same machine, Blender 2.79b (lists CPU and GPU)
  • macOS Mojave, Blender 2.8 (lists CPU only)
Additionally, on the same machine, it is possible to see the devices in GUI preferences window:
It may also be worth noting that the debug output produces this:
I0118 19:35:32.273550  2197 device_opencl.cpp:60] CLEW initialization succeeded.
I0118 19:35:32.282517  2197 opencl_util.cpp:779] Enumerating devices for platform NVIDIA CUDA.
I0118 19:35:32.282583  2197 opencl_util.cpp:845] Ignoring device GeForce GTX 1070, not officially supported yet.
I0118 19:35:32.282691  2197 device_cuda.cpp:2390] CUEW initialization succeeded
I0118 19:35:32.282703  2197 device_cuda.cpp:2392] Found precompiled kernels
I0118 19:35:32.284847  2197 device_cuda.cpp:2513] Added device "GeForce GTX 1070" with id "CUDA_GeForce GTX 1070_0000:01:00".
Using device: CUDA
Which apparently means that the device is found.
  1. Use the default startup.
  2. Download the script to test the listing of devices.
  3. Run path_to_blender2.8/blender -b --python blender_list_devices.py --debug-cycles --debug-gpu --verbose
Expected result:
At least 1 device name (CPU) is output, 2 or more if GPUs present.
Problem experienced:
No device names output, the array is empty.
You need to call prefs.addons['cycles'].preferences.get_devices() to refresh the list.
Havent checked code, but it is still unclear to me which (stored) preferences are actually used here.
If I do a fresh start [nuke my userprefs], then enable all devices in Preferences and save Preferences, then I get these reported by bpy.context.preferences.addons['cycles'].preferences.devices:
Intel Core i7-6700 CPU @ 3.40GHz
GeForce GTX 1080
Quadro RTX 6000
GeForce GTX 970M (Display)
the 1080 and RTX are definitely wrong.
But what works reliably is to query them using cuda_devices, opencl_devices = bpy.context.preferences.addons['cycles'].preferences.get_devices()
So .get_devices() makes it do the right thing...
Have a look at T57282 as well
@Brecht Van Lommel (brecht) get_devices() worked for me, thanks. On a side note, I've noticed that after I used get_devices() once, the devices started to appear in the list. What's a bit strange is that I previously did run Blender 2.79b in the background in a Docker container (via nvidia-docker) where Blender was installed from scratch and never ran with UI, and I did not run into this problem—the GPU was definitely working.
