Boolean error
Open, Needs Triage by DeveloperPublic
You will need inspect Macintosh. Not use Windows, Not use Ubintu.
MacOS 10.14.2
2017
27"
5K
Boolean error.
I put 3 cube with width then put other cube.
Push the 'N' key appear and click Tool tab.
Boolean on Brush Boolean click 'Difference' button
error there.
Then click (Remove All) cause crash.
Blender 2.6xx is much better perfect.
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.
Seems to be about Bool Tool Addon.
Cannot reproduce here though, working fine...
  • This has just been ported to 2.8 rBA0b4cfab541e3, are you sure you are using this?
  • if not, please use a recent buildbot build
  • if yes, what is the error you are getting [when using the Difference button]?
  • do you mean you have tested Windows & Ubuntu and the error/crash does not happen there? [quote "You will need inspect Macintosh. Not use Windows, Not use Ubintu."]
Marking as incomplete until we have that answered...
I already download daily build. Blender 2.80 is January 18, 2019.
Are you use focus Macintosh not Windows?
thx for the info
I use Fedora (linux)
question was:
  • have you tested Windows & Ubuntu and the error/crash does not happen there?
other question was:
  • what is the error you are getting [when using the Difference button]?
Oh well please transfer to focus Macintosh. I am use Macintosh only.
Well, thats fine, but to progress with this report you should answer the remaining questions.
(unless you insist that only someone on a MAC should help you fix problems?)
This might be related to MAC [although not very likely], but it would help if you at least let us know if you tested it on another OS (and it was fine?) if you mention this specifically... [otherwise it is uesless information]
I am wait for some one use Mac inspect.
Tested on Mac. Can't reproduce a crash, but the boolean result is bad in this case
Even though they are all set to Difference, the boolean result is wrong because of the issue with coplanar faces being generated in the center.
This is a known issue with the Bmesh booleans.
Anyway, re your original issue, be sure to run the latest version of the 2.8 beta and the latest version of the addon.
I always download daily build latest version 2.80.
(I am not sure remember 2.6x to about 2.73 something like that perfect boolean never problem.
I see picture.
Did you click (Remove all) button on Boolean yet?
Strange.
I am use MacOS 10.14.2 within dark mode.
Oh allright and I am wait for them to work on Boolean for Blender 2.80
Blender 2.80 (January 20, 2019) inspect. . . . there is no crash (Remove all) button.
When I click (Remove all) cause error some mess up disappear some object. I agree with you.
I inspect again again cause (Remove all) button cause crash just now.
Did you solve problem on Boolean for Blender 2.80 ? (January 28, 2019)
Boolean on Blender 2.80 is still bug! (January 29, 2019)
Focus on Macintosh. Do not use Windows.
Still 'bug' in what sense? It's not a clear to me if you are experiencing an actual crash or that the boolean result is not perfect in some way.
about Blender 2.6xx to Blender 2.73 (I don't remember version) there is no error boolean
Yes but what 'error'? In your original bug report, you mentioned a crash. Are you talking about a crash or the fact that the result is wrong?
  • Brush Boolean *** (Push the N key on Tools tab
Both I just inspect over again again I am tell you. Remove all button within "Brush Boolean" make crash still.
Yes face result is some bug not correct still
I have a hard time understanding exactly what you are trying to say. Here's what I can tell you:
  • The bad result of the boolean operation here, is because the Carve library was removed. Booleans fail with coplanar faces. It's a known issue
  • I could not reproduce any crash, although I'm still not sure if you are experiencing an actual crash
  • If there's a problem with booleans, as I've said before, it's highly unlikely to be Mac-specific.
Allright I show you youtube I create just now.
I have my bad english. I do use sign language as well and I am full deaf.
Youtube: https://youtu.be/aNceZGCGzEA
This again makes me think you are not using the latest version of the addon. Here it works. Do you build yourself?
Did you see youtube?
You did not pay attach I show you latest version
Jacques Lucke (JacquesLucke) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Mar 7 2019, 2:50 PM
This is the error I'm talking about when I try to automatically create the door and window holes in the Addon Archimesh. Not to create well the cuts of windows and doors by errors in the operations boleanas of difference.
Can you show snapshot to show proof?
