Unable to select vert' faces and edges in edit mode,
Operating system: windows 10
Graphics card: nvidia gtx 970
Broken: blender-2.80-fc6aac391679-win64
Can't select verts and faces in edit mode
Add a cube, Enter edit mode, try to select the verts and it won't work. Press A and it will still select all the verts faces or edges,
Cannot reproduce.
  • Are you using left or right click select?
  • Do you have a certain tool active in the toolbar?
  • Are you using the default settings? (File > Load Factory Default)
  • Are you using the latest build?
William Reynish (billreynish) lowered the priority of this task from 90 to 30.Jan 19 2019, 5:23 PM
I have a similar issue on builds from 08 - 12/02/2019 on windows, last build I had it working with was on the 18/01/2019.
Seems fine on Mac though (via bootcamp)
Build: windows 64 bit February 12, 01:10:03 - 036ec5cae4f7
iMac 2017
Windows 10 pro
Radeon Pro 580
So...
I can right click select verts on cubes.
On more complex meshes I can only select some verts on the mesh, even with box select. Edges and Faces are fine.
If I go into 'show whole scene Transparent' I can select verts normally.
The latest version has fixed this for me.
Jacques Lucke (JacquesLucke) changed the task status from Unknown Status to Unknown Status.Mar 7 2019, 2:47 PM
Jacques Lucke (JacquesLucke) claimed this task.
