Falling out of Dyno
Win 10 64 bit pro
i9 14 core intel extreme overclock
64 Ram
NVIDEA Titan Pascal
2.8 beta i98e4cbedbb7
In sculpt mode system repeatedly drops Dyno when you hit ctrl+z Also Symmetry lock is working even when de-activated
Also every time you change to a different mesh you have to re set dyno,,,,,if you are working on a full scene this gets a bit old. Could we get as check box that says: don't remind me till next startup please?
William Reynish (billreynish) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.EditedJan 20 2019, 6:54 PM
I cannot reproduce the issue. When I hit Ctrl-Z, Dyntopo stays on. Can you supply a specific set of steps to reproduce this?
Thanks for getting back. It seems that there is a small lag time in effect here. The program falls out of Dyno if you get to the last undo on a mesh. The problem is is that the Dyno 'check box' is on the opposite side of the screen from where you put the mesh in to sculpt mode and I (any user,) would possibly not notice that the dyno button had become unchecked when they got to the last undo.
The symmetry lock was my bad for setting it up wrong.
I still don’t get it. Are you saying that if you enable Dyntopo, draw 5 sculpt strokes, and undo six times, that Dybtopo becomes unchecked? If so, that’s not a bug - you are just undoing enabling Duntopo.
I see that now.... It seemed to me that once you had set dyno it should stay set however if that's what the program does then so be it.....I know now. It was just a behaviour that I found a little counter intuitive.
